Re: Can I replace my battery for iPhone 4s to battery...
You can replace it with an aftermarket battery. That takes opening the case and a bunch of fiddling around inside .. If you are good with tools and have a lot of patience then go for it .. look at ifixit.com or iphone4parts.com for the stuff needed .. Otherwise .. Get an external battery case like a mophie or find a local iphone repair place and pay them to do it for you..
Actually quite easily. Remove two tiny screws on each side of charger port. Then gently slide screen up towards top of phone about 1/4 of an inch. Then left off. Do a YouTube.com search for a video showing how. Good luck.
Generally look for a "certified by apple" mark. You could also look for an aftermarket product from companies like "mophie" (www.mophie.com), for a case with a built in battery.
It
isn't often that Apple gives specific directions about how to fix your
problem! Restoring the iPhone 4S will erase everything on it, so make
sure everything on the iPhone 4S is stored elsewhere prior to restoring.
To restore, connect your iPhone 4S to a computer with iTunes installed.
Click "Restore" on the iPhone 4S summary page (click on your iPhone
icon on the left menu to find this page). Follow the directions to
restore. If your iPhone 4S displays the text "Please wait. Very Low
Battery," leave it plugged in. This charges the iPhone 4S enough to be
able to restore. If the iPhone 4S hangs on this screen for long periods
of time, you may need a new battery.
Force restore mode
If
your iPhone 4S is hanging with an Apple logo, or exhibiting some other
software problem that prevents iTunes from recognizing it, you can force
it into recovery/restore mode and then use iTunes to restore the software. If
the device is powered off, plug one end of your USB cable into the
iPhone 4S and leave the other end disconnected. Press down on the Home
button, and keep holding it down while you plug the USB cable into your
computer. After 5-10 seconds, you should see a "Please Connect to
iTunes" image on the iPhone 4S, and iTunes should prompt you to restore
the software; follow the prompts and the instructions given above. If
the device is powered on, hold down both the power and home buttons
until the device reboots and displays the "Connect to iTunes" image
(generally, 5-15 seconds). God bless you
It
Force restore mode
If
It
Force restore mode
If
It
Force restore mode
If
(generally, 5-15 seconds). God blsss you
It
Force restore mode
If
It
Force restore mode
If
