manualzz.comhttps://manualzz.com > ... > Print & Scan
Ping command can see the printer. If an IP address is not allocated to the printer or it is in a different. LAN segment then ensure that either IPX/SPX or ...
set the ip address to be detected automatically in the tv network settings.
What you need to know is the encryption key used on the Wi Fi
If you do not know it it might be on the case of the Wi Fi access point device.
Otherwise you will need to log into the router by typing the router's ip address into an internet browser on the working computer.
Rough Translation: GoodeveningI have an accesspointcwa-854andI can notentertheaddress192.168.1.253.Do notknow ifthisis necessaryforfunctionsthatthe truthafter it isinstalledI failto connect.GabrielaBest
The schematic diagram is going to be very hard to get. We do repairs on this model. What information do you need? The most common problem is the capacitors on the power board. You can find this repair guide at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ If you need other information then let us know at: [email protected] and we will get glad to assist you in the repair.
Win XP has nothing to do with it. As you said you have a fixed ip for the router. Now you need to map the incoming requiest to the local ip address of the dvr. It is called Virtual server.
It would be pvc0/1 mapped to TCP/IP port 80 of the local ip address of the dvr.
Hope this helps. Write to me if you need more assistance.
Se puede cunfiguar el router sin el cd, para ello debes tipear la direccion the IP del router, la original es 192.168.1.1 el password deberia ser 1234, a menos que lo hayas cambiado.
Espero que esto te ayude, y por favor no te olvides the dejar calificacion.
Gracias.
Type the router's IP address in your browser address bar and hit the Enter key. The default IP is 192.168.1.1
Default password should be 1234.
