LAMP WENT OUT, THEN CLICKING SOUND. REPLACE LAMP AND STILL BLACK SCREEN AND CLICKING SOUND
Changed lamp and picture stay on for 1 1/2 min then video go out then audio follow. This is a Samsung DLP HLR 50 67WX/XAA,Is this an overheating problem with the lamp or is it a power supply overheating problem or the digital board?
Hello Check whether the lamp life hours are going to be out. Refer to its user manual for details. DLP chips fault is very rare; unless you have handled them very carefully. Check the lamp and BALLAST baord that supplies voltage to lamp. Picture of the ballast baord to your TV is attached.
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
