If there is no picture and 3 vertical lines in the center of the screen, stop. Turn off TV. You have no horizontal deflection happening. Lines will burn into crts and be permanently visible after repair.
No horizontal deflection is caused by Horizontal sweep circuit failure, maybe flyback transformer and associated components. More than a simple do-it-yourself repair.
I read that you can rub a magnet on the backside of the slider and it makes the screen turn portrait and horizontal - you can see that when you rub the magnet on the backside. I just rubbed the magnet with the slider open on the horizontal side (only the right side) - if you rub the left side it makes it portrait. I did that a few times and my phone turns horizontal now when I open the keypad slider. It appears to have worked doing this at this point.
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines.
good luck.
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
