Try it with short cut and manuallly from I/O devices, and nothing. The problem is with that server mode, and my cable is COM port, dont have a USB. I have a 3.0 version of soft., witch i downloaded from HP official site.
computer recognise a com port, and when try to astablish a conection, a pop up sed try to turn calculator in server mode. I tryed two aproces wit the problem and zip...
And hp is freez when i try that server mode.
My wish is to transfer some functions from my pc to HP?
Please help
You should get a USB cable.
If you do not want to, get a Secure Digital card (formatted in FAT). Turn calculator ON, Insert card in slot.
Then [LeftShift][FILES] Open the directory where files are. Select them and use the [Copy] soft key to copy files. Got to directory where you want them copied and Copy rhem there. Exit File Manager. Remove Card and insert in SD card slot in computer, etc.
If you install the latest ROM 2.15 (hpcalc.org) the USB transfer option in IO parameters will show.
Hope it helps
