Question about Logitech X-530 5.1 Surround Sound Speakers&Subwoofer - 970114-0403 Computer Speakers
My computer won't recognise all five speakers
Only left and right speakers are working
Posted by Maureen Hill-hornett on
john cordey
  • 730 Answers
I believe you need to go into audio settings via control panel and change two channel desktop speakers to five channel in the drop down menus.there is usually a test scenario for 5 channel that then pulses sound through each speaker separately to ensure your setup us correctly working .
Posted on Feb 22, 2015
I have a htr 6130 yamaha reciever and when i hook my five channel home theater system it plays for a while then when i turn it up to almost max it turns the unit off completly... how do i hook up my
Hook all the positive and negative wires correctly and read on the speakers and make sure you have them all in the right spot and if that doesnt help its probably because the reciever is maxed out wich is triggering a kill switch wich some recievers have as a safety feature so you dont blow your speakers
My speakers quit working. my computer doesn't recognise they are even pluged in. says no audio device. i was hoping to get the exact driver for lcs-2424 so i could reinstall it
if your computer came with a disk the sounds drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
3helpful
3answers
My left speaker doesn't work but my right speaker does. The cord to the left speaker is plugged in all the way.
Open the "Volume Control" applet & make sure the "Balance" setting is set in the middle of the scale. This way sound will go out through both speakers.
My right speaker does not work, but left does
tell me how to connect vose speakers to my desktop computor
1 speaker only working. why
I like your thinking...that's just too simple. Nope you must plug the left speaker into the right speaker and pug the power supply into the right speaker. Then plug the right speaker into the GREEN receiver.
That works if you have two speaker..(and/or a sub woofer) it you have four...five...then we use all of those pink, black, white, yellow receivers. But that is a lesson for another day...good luck my friend.
1helpful
3answers
One speaker wont work
if u have experience with the soldering of the terminals then you can open the speaker casing of the sub woofer and then solder the right speaker input wire.
dont do this if you have no previous experience and DISCONNECT THE POWER SUPPLY before doing any work inside.
Backpanel socket for microphone is not recognised. Speaker socket is alright.
in order to hear sound on the microphone you need to check the Mixer settings as the default setting for microphone (for playback) is mute as you would get some horrible feedback..
double click on the speaker icon in the bottom left and chose properties from the options menu you may (or may not) have the option to select microphone for playback, however there should be a setting for recording which should give you a slider to set the recording levels for the microphone, use sound recorder or other recording software to test microphone is working
My desktop pc wont recognise my speakers
Go to the control panel, open device manager, check the sound system. If you have installed a new O.S., then you will need to also install a new sound system. Perhaps it ac audio 97 or some other. Look for yellow exclamation mark or yellow question mark and right click on that and update drivers.
Hope that helps.
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
No Connection to Some of the Speakers...
Solved Problem! Hold down test/setup for 2 seconds, then cycle through and add each speaker back into the setup. Happened to me, it must have reset somehow. That's how you fix it!
Top Logitech Audio Players & Recorders Experts
Marvin
Marvin
Muzahura Frank
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
