Question about Janome Sewing Machines
Does my Janome Sewist 521 model require oiling?
Sew Happy
    Guru:
  • 96 Answers
One drop of oil under the bobbin case in the center of the hook, on the wick. Your machine doesn't need oiled like a vintage machine. Taking it in for service once a year is plenty.
Posted on Mar 05, 2015
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: Ineed a manual for a janome sewing machine model Sewist 525S
http://www.sewingstyle.com
Posted on Aug 04, 2009
Anonymous
SOURCE: I can't find the manual for my Janome Sewist 5255
My friend found the manual on line and downloaded it for me.I copied it and saved it so now I am in business again. Thanks
Posted on Aug 23, 2009
SOURCE: I have a Janome Sewist
some machine are self oiling, when they are run & they parts get warm to hot then the oil come out of the parts & it's self oil.
contact a janome dealer & ask if your model is self oiling
Posted on Nov 17, 2010
emedeiro90
SOURCE: Can you please tell me how to change the bulb for
You have to take off the cap to the screw on the side of the cover. It is just bellow the foot tension. and then unscrew the side. It will then come right off, you may have to tug a little. Then, you can take the bulb out and replace it.
Posted on Mar 04, 2011
SOURCE: My brand new Janome Sewist 500 is making noise - it's clunking as I sew. I'm sewing two layers of cotton twill, stitch A, length 2, tension 5. Help!
have you checked to see if the bobbin is in the bobbin case correctly
is it still under warrenty? you might want to take back to the place you bought it from & let them check it
Posted on Mar 10, 2012
Where do I oil my machine sewist 625e
Look on machine for little red dots with a small hole nearby. Usually these are near the threading points and also on the foot near or on the metal flap. Also they may be under the flap near the bobbin. Make sure you wipe the excess oil off before using.
Oct 16, 2014 | Janome Sewist 625e
Where does the oil go in a Janome 521 Sewist machine, what type of oil & how much do I use? Thank you.
Check your manual, some modern machines do not require oiling and will be damaged by doing so
Oct 16, 2013 | Sewing Machines
Mar 09, 2012 | Janome Sewist 500 Sewing Machine
I need a manual for sewist 509
contact Janome customer service about a instruction manual
Mar 02, 2012 | Janome Memory Craft 9000 Computerized...
Does janome sewist 500 sewing machine need oiling? The manual does not say anything about it.
probably has wicks then thatthe mechanic will lubricate during service. the manual will probably say to have it serviced annually and to brush out the bobbin area often. this is important as lint will build up.
Dec 31, 2011 | Janome Sewist 500 Sewing Machine
I have a Janome Sewist 525 and I love it, I've had for about 3 years and never had any problems. I have a question though. I have the manual that came with it and nowhere in the entire manual does it say...
Nov 17, 2010 | Janome Sewist 525S Mechanical Sewing...
Can't find my manual for old Janome sewer model 372 since I shifted house. Can I buy/beg/ steal one from somewhere?
Hi
I looked on the Janome site and couldn't find a manual for this model, even in their retired machines section!
Looking at the picture above, I think your machine is most like the 521. Here's a link to a partial manual for the 521 from the Janome site.
http://www.janome.com/documents/File/ManualFile/Sewist521.pdf
If it is not similar enough to your machine, go to the Janome homepage at www.janome.com and use the drop down menu marked machines. Browse through the various categories of machine until you come to one that most resembles your machine. Click on the link for that machine and then click on specifiaction and you should see a pdf icon and a download manual button to download a manual for your chosen machine. Hope this helps!
Sep 15, 2010 | Janome Sewist 625e
Sewing Machines Logo
221 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
