Question about Biostar G31-M7 TE Motherboard
Intermittent failure to boot up does not detect
Intermittent failure to boot up does not appear to detect the SATA HD on such occasions. 2 of 4 identical PC's with same software experiencing this issue. Most common message "reboot and select proper boot device or insert boot media in device and press any key" but occasionally also this " Boot device not found"
Posted by maloneyv on
Anonymous
  • 82 Answers
Hi.. have some idea on that... when you try to format your computer.. pls make the SATA as "first boot" or "second boot" then try to boot again your computer.. thank you very much...
Posted on Jul 08, 2009
The cpu doesnot detect the HDD. there is a boot failure.
are the cables in right power cable and the ribbon or sata cable in right?
Nov 28, 2013 | Mitac MSC-242 Motherboard
How to detect sata hard drive P4M800-M7 Motherboard the sata hard drive can't detect
Hi fleetpio,
1. How to detect sata HD?- I am assuming that you have fixed the hardware part. During POST (Power On Self Test) press delete key inyour keyboard.
2. After pressing delete, a menu like the image above will appear. use arrow key to navigate, enter to select, +/- to modify values, Esc to exit current menu and F10 to save settings. proceed to Features Setup and press enter.
3. Another menu will appear like the image shown above, on the Onboard SATA-IDE from IDE change it to SATA-IDE.
4. Press F10, Saves the current configuration and exit setup.
5. To verify if the SATA hard drive has been detected, look on your POST if the HD appears. If the full screen logo appears repeat Step1 proceed to Standard CMOS Setup, check if youre HD appears.
Hopefully this information helps.
Thank you for using FixYa.
Sep 01, 2011 | EliteGroup P4M800-M7 Motherboard
Found my old HD (Western Digital WD1200JD) and decided to use it as a secondary to my much smaller HD. I've plugged in the SATA port, heard it turn on with its unique noise, and I've gone to see if it was...
You need to configure first on your BIOS that it will detect 2 SATA Hard Disks so and set you Primary and Slave. If this doesn't work, basically your HD does not work anymore.
Mar 09, 2010 | Western Digital Caviar SE WD1200JD 120 GB...
BIOS CANNOT DETECT HD SATA
The problem is cause of Hard Disk Drive. To solve, follow by these steps:
1.Check and make sure the connectors and cables between your motherboard and HDD are not loose.
If cables and connectors don't have a problem:
2.Make sure your Hard Disk Drive is power on and running.
If not you have to change your HDD.
I wish you'll be useful.
Apr 14, 2009 | ASUS K8V-MX Motherboard
Asus motherboard cannot detect Seagate SATA drive
Does your internal speaker beeps or stops telling you there is no hd detection?
Try to put another hd.
If you are using Windows reinstall it.
Does the red light blinks
CHECK out the power chord to hd and all power connections from psu
Dec 11, 2008 | ASUS A8N-E Motherboard
Compaq Mother board
Sounds like your hard drive has crashed. If you are getting an audible click from the hard drive, it is the arm hitting. Even then, sometimes you can get them to boot up on occasion.
The hard drive/SATA issue would depend on your motherboard connection. I think that there may be adapters to convert from a IDE to a SATA, but I haven't ever used one.
Oct 11, 2008 | Compaq Computers & Internet
I want to install RHEL3.0 in SATA DeskStart HD using MSI SATA MB, but not detecting at OS installation time. HOW i can detect, Pls help me!!!!
You need to create a space for which to install Linux. That likely means resizing Windows. Partition Magic is a good Windows utility to accomplish this, although there is a Linux version called Gaprtedthat will do essentially the same thing. You download the Gparted live cd, burn to disk, and run it from your computer. You must go into "setup" and set your Bios to boot from CDROM before booting the Hard Drive. Once booted, follow the on screen instructions. Resize Windows, (but NOT before a thorough defrag of your Windows drive), and create a "blank space" for Linux. Afterward, boot your Linux distro, (RedHat 9 was a great distro, but a newer version of a Red Hat based distro would serve you better, sayCentOS or Fedora Core), and follow the online instructions. Good Luck!
Sep 25, 2008 | MSI 945GM2 H-F (816909015911) Motherboard
Windows XP will not pickup my 2nd hard drive (intermittent fault)
most likely it is getting ready to crash, remove your files and replace the HD very quickly.
[email protected]
Aug 16, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
Biostar G31-M7 TE Motherboard Logo
973 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
Ekse
Lee Hodgson
Lee Hodgson
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
