Need more information regarding your question.
If your error is about your images being brighter/darker whenever you shoot at different locations, then this is a normal feature when using Auto setting for your ISO. The exposure will always slightly change whenever the ISO changes.
If your problem is about too much noise, then this is a normal problem when you use very high ISO on the D80. You can remedy this by setting the max ISO to 400 but you will not be able to take non-flash pics in darker environments.
If your problem is the ISO levels do not go up a certain setting, change your MAX ISO setting to a higher number like 1600. At this setting, the pictures will be grainy and have a lot of noise so I recommend you convert the output to black and white.
NOTE: Please rate our help to keep this free service online
