ASUS P4P800-E DELUXE ULTRA ATA133 W/SATA,RAID,LAN(Gb),1394,USB 2.0&AUDIO (Retail Box) (MBASP800) Motherboard Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Chassis intruded Hi Been chewing on this problem for 2 days now and I can't figure out the problem. The mobo is an Asus P4P800-VM (the micro-atx version of the P4P800 series Since a couple of days however the problem started, it just won't boot. It says: Chassis intruded Fatal error System halted
Anonymous
Level 2:
  • Expert 110 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Answers
110
Questions
Helped
27713
Points
314
Can you access the bios? You should disable Chassis intrusion, I don't really see anyone needing it if it's just a home pc.
J ai beaucoup de probleme avec mon desktop p4p800-mx chassis intruded
You have a problem with the Chassis Intrusion part, of the Asus P4P800-MX motherboard?
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800MX/#download
The Chassis Intrusion header is below the CMOS battery to the left.
It is in-between the two black SATA connectors.
It is a 4-pin header.
From -> LEFT to RIGHT pins are numbered 1, 2, 3, and 4.
Put a Jumper Cap on Pins 3 and 4, and bypass the Chassis Intrusion option.
In the -> OS box, click on the blue Down Arrow. Now click on Windows XP.
In the drop down list, click on the + sign to the left of Manual (5)
Version E1880 - P4P800-MX user's manual (English version) E1880
Click on the blue -> Global
Go to Page 35. (PDF file page. Manual page is 1-25)
Chassis intrusion connector (4-1 pin Chassis1)
For additional questions please post in a Comment.
Regards,
joecoolvette
1helpful
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
I have a Asus P5VD2-VM SE and when i boot my pc this show me a message Chasis intruded System Halted someone can help to solve this problem
You will need to go into your system BIOS and disable the Chassis Intrusion Sensor. BIOS is accessed by pressing the "del" key during the initial POST screen (or when giant Asus logo is on the screen) .
Look through there and located and disable the chassis intrusion sensor. If you can't find it, reference your manual for the board. If you don't have one, one can be downloaded in PDF format from the Asus website.
Be careful when in the BIOS, changing anything to an incorrect value could render your system useless! Don't play with anything, unless you explicitly know what you are doing, and what the setting does...
Be sure to "Save and Exit" in order foe the changes to stick.
3helpful
2answers
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
2helpful
2answers
2helpful
3answers
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Asus P5VD2-VM SE don't detect sata hdd
What processor are u using & which OS have u installed? Try using WinXP_ServicePack-3.........sodeep
3helpful
2answers
Chasis intrded fetal error system halted problem plz hep me
somewhere on the motherboard there should be a switch or jumper to turn it off look for directions either on case somewhere or on motherboard
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
