Question about AcuRite Acu-Rite 00754 Wireless Thermometer
How do I reset the remote after changing the battery life.
AcuRite
    New Friend:
  • 20 Answers
To reset your unit, please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac. Then, follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Posted on Mar 17, 2015
How to change battery
Either the remote control is regular size or miniature like the remotes for cars. The only real difference is the type and size batteries it uses. The regular size remotes usually use 1 or 2 "AA" or "AAA" batteries, or occasionally, a 9 volt battery. The miniature remotes take "button" batteries that are available at Radio Shack or the big-chain drug stores like CVS. Whether the batteries are the regular type or miniature here's what you do: On the back side of the remote there will most likely be a small phillips-style screw in the middle. Remove this screw and then you will be able to open the battery compartment door. Write down or take pictures (better) of how the batteries are configured and note this as you remove the old batteries. Radio Shack has a battery tester. If ALL the batteries are still good, then the remote is defective. If ALL the batteries are dead or very weak, then most-likely the remote is working fine & will come right back to life. Enjoy!
Jun 10, 2014 | Sanyo RCS-SH1UA Wireless Remote Control
HOW DO CHANGE THE LEAD REMOTE
you just swap them out and sync up the new one
Mar 06, 2011 | Nintendo Wii Console
NEED TO RESET OIL CHANGE LIGHT
How to Reset the Engine Oil Life System
The Engine Oil Life System calculates when to change the engine oil and filter based on vehicle use. Whenever the oil is changed, reset the system so it can calculate when the next oil change is required. If a situation occurs where the oil is changed prior to a CHANGE ENGINE OIL SOON message being turned on, reset the system.
Always reset the engine oil life to 100% after every oil change. It will not reset itself. To reset the Engine Oil Life System:
Display the OIL LIFE REMAINING on the DIC.
Press and hold the SET/RESET button on the DIC for more than five seconds. The oil life will change to 100%.
If the CHANGE ENGINE OIL SOON message comes back on when the vehicle is started, the Engine Oil Life System has not reset. Repeat the procedure.
Good luck and thanks for your question and I hope my suggestions help. burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Jan 03, 2011 | 2008 Chevrolet Impala
Sanyo remote will not chang to a lower channel
If the channel down works on the Tv, the problem is a worn or fluid damaged channel down button on your remote control. Also check the batteries life in the remote control and change if drained.
Feb 14, 2010 | Sanyo Televison & Video
The change oil message came on.I changed the oil and reset the message center, but the message comes back when I start the vehicle up.Is there another way to reset it to keep it off until the next oil...
On the console, where the oil change light is on, scroll through the items until you get to oil life. Once at oil life, hold the reset button and it will say Engin oil new? Press reset again and this should set you oil life back to 100% without needing to disconnect your battery
Nov 28, 2009 | 2004 Ford Explorer
Even with new batteries the remote control has to be pressed continually until the desired result is seen on the VCR. Any ideas?I just changed the batteries and the remote seemed to have lost a lot of its...
Is the remote old or over used?
Remotes don't last a life time. Over time they will wear.
If you take it apart you'll see the carbon coating for some of the buttons is wore off. For a $10 bottle of repair fluid you can recoat and get more life out of it, or buy a replacement from either ebay, or type in the model number into yahoo and see if you can find a replacment remote.
Nov 23, 2009 | Sony Televison & Video
Vrdvd4005, remote quit, changed batteries,
I would almost stake my life that the inferred diode is the problem, this has happend to mine in the past I replaced the diode and it has worked for years now.
Jul 07, 2009 | Sansui LCDWDVD320 32 in. TV/DVD Combo
I have a 2005 Venture and have not been able to reset the change engine oil light. After repeatedly pressing the trip/reset button for 2 minutes the message center was still flashing change engine oil and...
Notes ENGINE OIL LIFE SYSTEM
HOW TO RESET THE ENGINE OIL LIFE SYSTEM
The Engine Oil Life System calculates when to change your engine oil and filter based on vehicle use. Anytime your oil is changed, reset the system so it can calculate when the next oil change is required. If a situation occurs where you change your oil prior to a "CHANGE ENGINE OIL" message being turned on, reset the system.
  1. With the ignition key in "RUN" but the engine off, repeatedly push the trip/reset button until "OIL" is displayed on the Driver Information Center (DIC).
  2. Once "OIL" is displayed, push and hold the trip/reset button for five seconds. The number will disappear and be replaced by 100 (indicating 100% oil life remaining).
  3. Turn the key to "OFF". If the "CHANGE ENGINE OIL" message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the procedure.
If this does not work you may have a problem with your instrument cluster.
Mar 22, 2009 | 2005 Chevrolet Venture
AcuRite Acu-Rite 00754 Wireless Thermometer Logo
671 people viewed this question
Top AcuRite Measuring Tools & Sensors Experts
Tom Chichester
Marvin
Marvin
Are you an AcuRite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
