Just charged w/AC adatper, volume got really low, then screen wouldn't come on, Blue wheel is still lit.Just charged w/AC adatper, volume got really low, then screen wouldn't come on, Blue wheel is still lit.
I treid the solution post previously. It didn't work. Its still coming up with a blank white screen.I treid the solution post previously. It didn't work. Its still coming up with a blank white screen.
You can't post conmments that contain an email address.
Your battery is not dead because if it was, then navigation wheel would not be lighting up. Your screen is blank because when you touch the navigation wheel, you probably decrease the brightness of the screen. Turn the wheel counterclockwise, as this will brighten up the screen display. Press the center button when done. Reply back if this solution does not help.
Your Screen is most likely broke because even if somehow accidentally the brightness on the screen setting was messed with it wouldn't make it white the only real solution is to buy a new one or learn to navigate the device without seeing
You may need to now reset the player, that may have been a bit much for it.
To reset your Sansa Mp3 player.
Slide and hold the Power switch up for approximately 20 seconds.
Release the Power switch.
To turn the player on, slide the Power switch up then release instantly.
If that does not get your player working again, try and Format to clear any corrupt files that may be present.
Sansa Mp3 player frozen? How to reset and...
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following:
2. change lock switch to orange position
3. Press and hold rec button (at left side)
4. while pressing the rec button, turn the player on
5. it will appear the boot menu. connect the USB cable and try to continue the firmware
6. if it doesn't work, do a firmware downgrade. download this file:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
7. execute the application while in boot mode
good luck
darek
