Question about Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
Dell mini error code0f00:065d how can I fix this
Won't start up to windows xp
I need mavis beacon that is compatible with dell inspiron mini.
You will need to know the operating system or model number to determine which version of a Mavis Beacon product is compatible with the Inspiron Mini. The Inspiron Mini 9 came with Windows XP. The Mini 10 1010 could have XP, Vista or Windows 7. The Mini 10 1012 came with XP, Windows 7 or Ubuntu Moblin. The Mini 12 1210 came with XP or Vista.
Mavis Beacon Teaches Typing v2 , http://www.broderbund.com/p-952-mavis-beacon-teaches-typing-powered-by-ultrakey-v2-personal-edition.aspx , should work with Vista or Windows 7. This is the current version and works with Windows 8 and Windows 10. Mavis Beacon Teaches Typing version 18 and version 20 Platinum both work with XP and Vista.
I hope this helps.
Feb 08, 2018 | Dell Computers & Internet
Stop c0000218
Which operating system ????
If you've just installed Windows XP on your desktop and you've received the following error "STOP: c0000218 {Registry File Failure" you're not alone.
This is a known issue with XP that can arise from incompatible hardware being installed with XP or, in the worst-case scenario, from a faulty hard disk.
Luckily, it is fairly simple to figure out if your disk needs to be replaced or if a software fix is enough to solve the problem.
Check if your hardware is compatible with Windows XP.
You can find compatibility information at the official Microsoft marketplace website (see Below).
http://www.windowsmarketplace.com/
Use the recovery system if your hardware is compatible but is still not working. You can access the recovery console by simply putting in your Windows XP CD before booting your computer.
You will be asked whether you want to "Repair or Recover.
" Simply press the "R" key.
Type in your administrator password.
(You must have admin access to use this option.)
Choose to use the "chkdsk" command line, which will allow you to check your disk.
Once in the chkdsk use the "chkdsk /r" command to check your hard disks for errors.
Press "Enter" to start the disk check.
Type in "chkdsk /f". If any errors are found this will allow your computer to attempt a fix of the broken drive.
Restart your computer after the disk fix has been performed, and attempt to run your Windows XP setup again.
You should have no input while the chkdsk utility is in progress any input might further damage your computer and hard drive
Replace your hard disk if the setup fails with the same message. At this point your hard disk is more than likely broken and needs to be replaced.
Jun 25, 2013 | Dell Computers & Internet
OS install - dell mini 910
When your PC starts you have a message like "Hit DEL KEY to BIOS"
if you press that key, a menu appears. Look for a Menu like "boot menu"
Them you have to change option fisrt start, to external devide or CDROM.
Aug 04, 2012 | Dell Inspiron Mini 9 Laptop
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
I want to install windows xp on dell inspiron mini 1018 but i am not able to install.some blue screen comes.please help
turn off your antivirus before you try to revert back to xp. your system antivirus might see this as an attack on your windows 7,thus it won't allow you to install a different system.
Feb 25, 2012 | Dell Inspiron Mini 10 Netbook
On start up get windows xp screen, but won't boot up
Better run the Dell diagnostics.. That will let u know the issue
http://adf.ly/3pD7A
Nov 13, 2011 | Dell Inspiron Mini 10 Notebook
We can not start the Mini 1000, error system32/hal.dll
It is the windows start up file error and your windows needs to be repaired.For that you need to have the windows CD with you and you can get instructions on how to do it using the below link,
http://infoteknotainment.com/fix-corrupt-or-missing-windows-xp-system32-files-using-recovery-console
If you need suitable assistance you can also get online technical support. I would suggest you to contact TheBestPcDoctor. I get my issues fixed by them.If you need you may also contact them @
www.thebestpcdoctor.com or via 877-407-9229
Oct 04, 2011 | HP Mini 1000 Netbook
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
Dell mini inspiron 9 - operating system not found
On my Dell Insprion Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Oct 14, 2009 | Dell Inspiron Mini 9 Notebook
DNS error
to fix to the "DNS error" in windows
XP. go to>Control Panel -> Admin Tools -> Services
Find DNS Client and Stop it, wait a few seconds. Then start DNS CLient
again. Can continue without rebooting or reconnecting.
.hope this helps pls appreciate by rating it
Oct 23, 2008 | Dell Dimension 2400 PC Desktop
Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
