Question about Samsung DVD-V9800 DVD Player/VCR
This player is relatively new and unused although over a year old I have only recently been using it. I first played 2 discs w/out any problem than a tape. On trying to play a disc is when the stated problem arose. Also my remote, despite new batteries, does not fastforward. Could the remote be the prime problem re playing a disc?
Posted by NEAL MCLAUGHLIN on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: I have a Samsung DVD-R 120
Exactly the same problem with mine. I even went shopping today after months of buying dvds that wouldn't play, to buy a new player. I then had a silly revelation. I pressed open and with a tight grip on a cotton bud I swept all that I could reach within the recorder. Can you believe it but it worked. Now I have my multiregion back and it has so far played all of the PAL 2 and PAL 4 dvds that I have bought since the PSO came on months ago. I don't what the problem was or if this is relative to your problem but I wanted to let you know....
Posted on Aug 06, 2008
Anonymous
SOURCE: wont play dvd discs
Hi all.
I have 'a' solution. It is a pain in the neck but what I do is just keep closing the drawer after the message "this disk can neither be played or recorded, please check disk" comes on screen until it does what it is meant to do.
I am only doing this to clear off the hard drive then I am going to buy another machine.
Posted on Jan 04, 2009
Anonymous
  • 93 Answers
SOURCE: dvd keeps saying loading but won't play
Sounds very much like you have a either a dirty laser, or a laser unit failure. Put a cleaning disc through the machine, and see if it improves. If not, then you need to either have a new laser fitted, or a new machine.
Posted on Mar 14, 2009
Anonymous
  • 7 Answers
SOURCE: DVD won't play
Its Sounds as if your DVD went kaput this tends to be a problem with most combination players usually the VCR goes first also you may need to run a cleaning CD made for DVD players maybe that will help.
Posted on Apr 03, 2009
Anonymous
  • 153 Answers
SOURCE: Cannot play this disc
1) Physical fault
use a blower and clean the internal parts by blowing
2) fault in the lense section of the player
may need a thorough cicute scan
Posted on Sep 28, 2009
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Jul 31, 2010 | LG Televison & Video
My phillips dvp5140/37. video player ,stops
Does the player ask for a password?
If it does look in the manual or contact Philips on their website.
This helped me a lot once.
Jun 13, 2010 | Philips DVP5140/37 DVD Player
Bose 5 disc cd multi changer wont load any discs from the magazin
That is usually because of dirty or defetive lens, as teh player cannot read the initial track of the CDs.
Try first using a len cleaner , like the ones here.
If this does not work it will be necessary to take apart the unit and accees the lens to clean it, or replace the lens pickup. The repair must be done by a technician.
In this case call the number listed on the owner manual to get assistance
Dec 15, 2008 | Audio Players & Recorders
Sampo 612N DVD Player
Sorry for the very late reply because I have left this site for awhile. "X" represents a variable anything from a number 1-6, so instead of an "X" you input a number from 1-6. Got it?
Good luck
Apr 20, 2008 | Sampo DVE-612 DVD Player
`Sony CD player won't play burned discs
Many of the older Car CD Players will not play CD-R's or they may with static sounds behind the music. What you need to do is try using a different brand of cd-r disc. If this doesn't work then it means that you may need to replace the CD player because the model that you have may not be decoded in order to play CD-R, CD-RW, play MP3's or anything of that such.
Get back to me if this doesn't work I'll help you square it away.
Nov 19, 2007 | Sony RCD-W10 2-Disc CD Recorder
Sony Player
THAT AINT THE PROBLEM
OLDER CD PLAYERS REQUIRE A SLOW BURNT DISC
SIMPLY BURN AT A SLOW SPEED
1 x , 2x, 4x. 6x. might work 1 X and 2 x WILL FOR SURE
Nov 18, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Samsung DVD-V9800 DVD Player/VCR Logo
46 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
