Question about FUJIFILM Cameras
Is it possible to repair a digital camera where the light sensor has stopped working
NoName Jack
  • FUJIFILM Master
  • 1,150 Answers
Yes.... It's possible. But finding the right person to do it is another thing. It may cost as much as the camera. Thats why it's become a throw away world
Posted on Feb 21, 2015
Water in inside battery,its possible repair?
It is possible to repair. But you would need to buy another camera on ebay like this for parts with a broken screen, it will have those circuit boards to replace in your camera. Your cameras circuit boards are damaged by water. You can try to take apart the camera and use a fine needle to clean out white rust from the elements of the board, it may work too. To do that you need a very fine screwdriver and a good magnifying glass with good light.
Jul 14, 2014 | Sony Cyber-Shot DSC-TX10 Digital Camera
DMC TZ3 lcd sceen ok on playback no image on shooting
Sounds like a possible bad CCD sensor.
This camera had ccd problems.
See this link:
http://www.merchantcircle.com/blogs/Darntoothysam.Digital.Camera.Repair.952-236-7243/2009/7/Digital-camera-defective-CCD-recall-Get-your-camera-fixed-FREE/301718
Call the factory for possible free repair.
Oct 29, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Kodak EasyShare M530 camera. My flash has stopped working on it. I have not changed any of the settings on it. I dont know what has happened. Is there a reset button on this camera or anything?
I see you mentioned the flash has stopped working, yes in the menu just look for the option to reset to factory defaults or reset to defaults, this will reset the camera to the original settings.
But then I see the Flash is the issue on the camera and it is possible that resetting the camera will not help at all.
I t will be best to have the camera check on the issue, or have it service for proper repairs on the issue, this can be a possible Hardware failure.
Is the camera in warranty if it is then calling Kodak is the best possible option that you will have for the best result in having it repaired.
I hope this helps.
have a nice day,
mvincentc
Sep 08, 2011 | Kodak EasyShare M530 Digital Camera
Hi, i just dropped my nikon digital camera and it's stopped working! when i switch it on the camera computer does not work - what can i do??
You've likely cracked the board inside. DSLR's do not take lightly to drops as most everything inside of them is hard mounted to the frame which is mounted to the casing so when any physical damage is experienced it transfers to the weakest part. Almost every time the damage is the CMOS sensor or mirror system, but if the drop was serious enough it will crack the main board.
I would still have it sent out to Nikon for repair estimate, it's likely less than the price of a new camera.
Dec 08, 2009 | Nikon D60 Digital Camera
When I rotate my camera the image won't turn also.
Check to see if for some reason this feature is dissabled in the set-up menu.
If the menu settings are okay, it is possible that the position sensor or its related circuits have failed.
The camera would need factory level service if there is a failure.
Jerry G.
Jul 08, 2008 | Canon PowerShot SD1000 Digital Camera
Flash light does not work
Hey VY555,
I'm sure it's possible to replace the flash on your camera, but it should be done by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out to get serviced. Without and authorized service technician looking at the camera and diagnosing what is wrong with it I would not be able to give you an estimate on the repair cost. I will say that with digital camera repairs it is often more expensive to repair than replace the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Olympus Stylus 740 Digital Camera
Fuji FinePix S20Pro Digital Camera - Sensor broken
Most likely no. You are probably going to have to send it in for repair or return it to the store.
Feb 29, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Flash won't work - possible bulb failure?
Check Kodak for repair quotes likely hood not economical though
Aug 07, 2007 | Kodak EasyShare DX6490 Digital Camera
Cameras Logo
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
