Aqua Glass Jacuzzi Bathtub pump motor. Model #1013039 HP 2.0S Volts 115 1 speed GE Mod # 5KCP111ES003X SER #2WFN V 115 PH 1 HZ 60
SOURCE: JACUZZI HOT TUB J365
MOTOR TO HOT TUB KICKS OFF ON HIGH SPEED AND GETS VERY HOT AFTER RUNNING ABOUT 20MINUTES AND STARTS BACK UP IN LESS THAN A MINUTE,BUT CONTINUES TO KICK OUT ,IVE REPLACED THE MOTOR AND STILL SAME PROBLEM..
SOURCE: Hydro maax wirlpool bathtub Model # J6061 Pump will start
Can either be a bad motor or if the motor has a capacitor, it needs to be replaced. I would call a service professional to come out.
SOURCE: my brand new jacuzzi bathtub motor just clicks and
check 2 things......1) see that the power is connected and that the breaker is on.......2) if everything from 1 is a yes check the hose that runs from the switch to the motor it may be lose, disconnected or has a hole in it. If you have anymore questions just ask. I am a professional plumber for over 25 years
SOURCE: Does new jacuzzi bathtub nead the heater
Jacuzzi heaters are an addon and are a convnience accessory. They are not required for functionality of the unit. I personnaly do not have a heater in either of mine.
Thx
Deathstalker
SOURCE: whirlpool tub pump only runs in slow speed
give aquaglass a call at 731-632-0911 they will be glad to help you,i worked for them at one time
