F40 error code
SOURCE: kenmore oasis elite
If it's not listed in the rear of your manual??? Then you will need a Technician. Let me know if you find the solution in your book.
SOURCE: Kenmore oasis dryer model 110.6706 flashing F40
Just had one of those calls today......what I found this time was simply that the blue communication wire harness (I think it's a 3 wire, very easy to spot, runs from the side of each control board) had popped loose from the MCU. Inspect each connection for damage, and re-seat the connectors back into the controls. If that doesn't do it, you can measure for voltage (no fun with those tiny connectors) to the MCU. The code F-40 simply means loss of communication between the CCU and MCU. So it actually could be either board. Check it out and re-post if needed.
SOURCE: error code F44
The F44 error code on this type of dryer indicates a blower motor control board failure. Since it happens only occasionally, then you could have a loose wiring connection or a partial obstruction in the blower housing. Complete details of the troubleshooting for this error code are included in this link of a previous answer: What does the fault code F44 indicate on my Kenmore Elite Oasis dryer?
I recommend that you unplug the dryer and check the wire harness connections if you are confident that you can safely access the internal dryer components. If you find a loose connection, then tightening it or plugging the harness securely into the connection will likely correct this problem.
SOURCE: Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
