Question about Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952
My wash machine does not let water in
I believe I need to intake valve
Steve
  • Kenmore Master
  • 3,289 Answers
A solenoid valve is used to allow water to enter the machine at different times of the cycle. The home's shut off valves above the hoses must be on.
The water may not flow if the hose is clogged, the filter at the input to the washer is clogged, the solenoid has failed, electronic control for the solenoid has failed, or a door switch - or other sensor - has failed.
Shut the water valve off and remove the hoses from the washer - note which is hot and cold. Direct the hoses into the wash tub of the washer. Open the shut off valve briefly. Water should come out of both of the hoses at about the same rate. If not disconnect hose from the valve for cleaning or replacement. Then check the hose connection on the washer - remove and clean or replace any filter found. Once cleared or replaced - reconnect hot to hot and cold to cold and try filling again. If still not working, you'll need to check for operating voltage at the solenoid when it should be open. If voltage present and not letting water in - replace the solenoid. If voltage not present - it could be a sensor, control, etc.
These appliances operate at deadly voltages. Please, do not attempt if you're not sure how to perform the work, use the tools and meters or know what you're doing. Good luck!
Posted on Feb 20, 2015
Whirlpool AAA Class Dishwasher
FA - Aquastop error
Check water supply. Low water pressure? Does the machine fill up with water in under 1 min? If not, thats your problem. If this happens during wash cycle, it could be the intake valve for the rinse cycle that is your problem, if you hava doubble/tripple intake valve that is.
Intake Cold water filling into machine while turned off
You have either a faulty solenoid valve on the cold intake or you may have knocked some limescale into the valve while changing the pipes. Try some descaler in the valve first and operate a few times. Hope that makes sense!
Soloniod faulty
check the filters
at the intake the solinoids {water intake valves}
there is a small filter
you need to turn of the hot and cold water
like under the sink
take off both hozes hot and cold
then take out the filters at the machine intakes
and clean them
you can take out the filters
using flat nose plyers to gently pull them out
clean them out from brown crypto spyridion carcus
and other rubbish
you can leave the filters out and run thru the whole machine on like 30deg with a calgon tab
does help {not scotland no lime here }
then place the filters in the intakes again
or replace the valve if it leaks water after cleaning
then the spring in the valve of the valves solinoid coils isnt so good
and needs replaced
but can just be a blockage
above all if its a new machine you just got
perhaps it been in a low presure area so the valves will be
low presure hot and cold
usually its just the hot that is low presure
so you need to check the cold water is getting plenty on like 2 -3 bar presure...
Washing machine not filling
if no water at all is entering the machine then the water intake valve is blocked and/or needs replacing. another answer which is obvious but sometimes missed is the water is not switched on
When i set the programme to wash it only fills with a little water and then stops - not even washing
You most likely have a faulty inlet valve.
I believe in the Bosh, there is a 2way inlet valve for the cold intake and a single valve for hot water.
Remove the top panel see where the hoses connect to the back of the machine. these are your inlet valves.
You most probably need to replace the cold inlet valves.
Get the part before hand. Turn off machine from the power source. Observe the wire connection to the valve solenoids. Replace the valves and fit the hoses as they were. Take notes or pictures so that you remember how they fit.
If you have questions let me know.
regards
Ash
Washer stopped working all together
Hi,Check your water solenoid valve, the part where you connect (2) hoses, could be burnt out, sometimes they do, especially if your water pressure home (building) is low, or could be your motor, remove back of machine and check water valve, check valve with ohm tester, or visual check can tell you, if burnt out, replace it, few things could burnt out, motor, capacitor, switches/relay etc, but first check water intake (solenoid) valve, also,check / reset, fuse/circuit breaker, probably went of, when burning smell occurs, ( happened) if it's not your water intake valve, let me know, we can check other possibilities. but i believe it's your valve, good luck.
My Kenmore front loader will fill with 3 or 4 inches of water on it's own, when it is off and door is ajar??
Hi, possible your water intake valve are faulty, check back of machine where your( 2) intake water hoses are connected, shut water off, remove and clean water valve, it's possible you got high water pressure in you home (building) or your water valve maybe strain, or has a mechanical fault inside of it, you can remove back of machine, remove water solenoid valve, put valve apart and clean plunger, put valve together and see if same thing happened, if water still comes in after cleaning valve, you should replace it. before doing any repairs unplug machine, (disconnect power) good luck.
3answers
Water intake and wash cycle
change the water intake valve, that is the only answer i think
Open Questions:
See all Kenmore 500 3.5 cu. ft. Top-Load Washing Machine Questions
Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952 Logo
Michael Thomas
Michael Thomas
Paul Carew
Vernon Taylor
