Dishwashers Logo
A
Anonymous Posted on Feb 20, 2015
How to fix a Bosch dishwasher a anti xx with a eo9 fault
My dishwasher is not heating up
Dado
Level 3:
Master:
  • Bosch Master 511 Answers
  • Posted on Oct 08, 2015
Dado
Bosch Master
Level 3:
Master:
Answers
511
Questions
0
Helped
482885
Points
1313
E09
Heating circuit fault.
As above, this is most probably going to be an issue with the heating element as the thermistors have their own fault codes below.
Dado
2 Related Answers
Anonymous
  • Posted on Jan 17, 2010
SOURCE: Bosch Classic xx dishwasher; not
slimline classic xx bosh dishwasher not pumping out water??
Ambari
  • 901 Answers
  • Posted on May 24, 2010
SOURCE: where do I find the pcb on a Bosch dishwasher clas...
Check at front door top. You may have to open the screws around the door.
My bosch classic xx dishwasher has an error code E04. What do i need to do to resolve this?
You can google your question for answer
About 15,800 results (0.65 seconds)
Took about 2 seconds to find answer. Look in the instructions that came with unit.
ttps://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-e04/
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Error09 on Neff dishwasher SD6P1F
that E# is not listed in the manual as something they think the user can fix.
"You can rectify certain faults yourself (see following fault description), for all other faults please contact customer service and state the indicated fault E:XX"
Sep 21, 2014 • Dryers
2helpful
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Bosch error code e22
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/dishwasher-fault-codes/3058-bosch-sms-series-dishwasher-fault-codes.html
Bosch classic xx diswasher not emptying
Open kick panel under front of dishwasher. With flashlight, observe drain selenoid during exhaust cycle. If it does not operate, it must be replaced.
Where do I find the pcb on a Bosch dishwasher classic xx?
2helpful
Bosch classic xx 5 mintues into the wash, stops and tripps elec.
Hello Sir,
I think that this is due to a faulty Main box Fuse. This usually happens when the heating elements of the washer go on. Try to inspect for faults, cracks or breakages in fuse box or in switches.
Thank you Sir,
Have a nice day.
3helpful
3helpful
3answers
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
