My is not working it shows the senseing light on
SOURCE: Dryer stuck in sensing mode
hello
i have a hoover mega load condencer dryer HNC 375 T
after switching on the filter sensor light flashes
cleaned all filters but still the same
can anyone help
SOURCE: Whirlpool Duet dryer won't move past sensing function on any cycl
Found the culprit. The thermal fuse was blown. Had no conductivity with ohm meter so I placed a jumper around it and presto dryer runs. Cleaned the exhaust and fan but found no blockage and really was not that bad. Hoping maybe just a weak part. The model on the Whirlpool Duet electric dryer is GEW9250PWL I believe the the last three are just the color. The part number on the Thermal Fuse is #3392519. This is easy to get to through the front panel just below the load door. Hope this helps some else out.
SOURCE: Whirlpool Senseon Dryer-drum doesn't spin & stuck on sensing mode
the belt on the drum could be broken
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
SOURCE: Whirlpoold Duet dryer "sensing" lights up but will not run?
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
