Only one element has gone out on my stovetop. do I need to replace the entire top or just an individual burner
SOURCE: Schott Ceran cooktop on Maytag range
try clr from a local supermarket.it comes in a green plastic bottle.wipe the burner generously but not soaking wet with it and turn the burner on the lowest setting.then use a metal scouring pad and LIGHTLY scour the burner.
SOURCE: I have an electric Maytag,digital
Hi Mearill,
Happy to help you!
At this site you may download a manual !
http://www.maytag.com/support/manuals_literature.jsp
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
SOURCE: MAYTAG Model ME5770AAW Ceran Top Stove
I had the same problem, but a plastic top burned on my range top causing a black spot. I used oven cleaner. Let it sit a while on the spot(hour or two), then use a razor to scrape. It looks good as new. I had used everything recommended by the manufacture before I tried this.
SOURCE: I have a Schott Ceran cook top that is marred with
Use oven cleaner. Spray it and let it sit on a couple of hours. Scrape with a razor blade. It worked for me after trying everything recommened by the manufacture.
SOURCE: Broken glass top on my Maytag Schott Clean (upper
u have to replace the whole top and its about 400 to 500 dollars just for the part cheaper to buy new
