If you can control + alt + delete and start over, then it may/may not work, then they're probably right and it's a software problem and not a hardware problem like overheating.
The first thing I would do is turn off all background programs. Here's how you do it:
Start
Run
Type "msconfig"
Hit 'Enter'
Go to the 'startup' tab
Click 'disable all'
I'd go back up the list at this point and recheck 'touchpad' if it's there. There often is such a thing on a laptop.
Click 'OK'
Restart the computer
When the computer starts back up, you'll have to check a box that appears that says you changed some system setting (or some such), just check and continue. You won't see it again unless you repeat the above process.
See if you continue to lockup.
If you don't, then you know one of those programs in that startup menu is causing the problem. You can repeat the above process and turn them on one by one (as opposed to disable all) (or leave them all off for a faster, smoother running machine!) if you want to and figure out what was causing the problem.
SOURCE: Lock-up
1.-update yours chipset driver via VIAarena 2..-update your se twister video driver 3.-remove from your laptop the fallowing file from micrisoft:Q317277 4.-disk index off 5.-video mem at 16MB. 6.-For myself, I am not using synaptics driver, I removed and auctomatically use microsoft touch pad driver.I increased my page file size to 950. Let me advise all you, it is a recipe, I tried upgrading only drivers, and then I get some freezing,only after I removed windows update file:Q317277 i got to be free of crashing also, please update your battery and firmware driver from compaq. in addition to all that, i took my laptop apart and replace the *lousy* thermal pad with arctic silver 3. Works like a charm now - only recommended if your warranty expired Good luck!
There was another message listed with mine. My message starts with "My new computer locks up...". The solution included the eroneous message that was from a laptop. My computer is a Lenovo tower. Could you re-submit just my message for evaluation? Thanks, Dave
