Question about Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011
I want to change transmission filter and transmission fluid on MERCEDES ML 350 2008
Check the transmission housing for the following; external filter and a drain plug. If there is a drain, then changing the fluid is an easier task. The car must be supported securely. You will need a drain pan, replacement filter and fluid. Make sure that you purchase the correct type of filter. It may be easier to have this done at Midas and it would be safer.
Posted on Feb 25, 2015
Dec 25, 2014 | 2006 Mercedes-Benz ML 350
Dec 16, 2013 | Cars & Trucks
May 25, 2011 | Mercedes-Benz ML350 Cars & Trucks
Mar 29, 2011 | 1998 Ford F150 Regular Cab
Nov 26, 2010 | 2007 Mercedes-Benz CLK350 Convertible
Dec 29, 2009 | 2002 Mercedes-Benz M-Class
Aug 02, 2009 | 2007 Mercedes-Benz ML350
May 04, 2009 | 1999 Mercedes-Benz M-Class
Jan 05, 2009 | Mercedes-Benz C230 Cars & Trucks
508 people viewed this question
