Question about Altec Lansing ATP 3W Computer Speakers
My ic is broken - Altec Lansing ATP 3W Computer Speakers
Posted by winifredobautista on
How to replace roland xp 50 keys And also repair outputs
Disassembly the unit.
Your question is less detailed. If the keys is broken,replace with new.
If you mean "How to",then you need the service manual.
Outputs problem,usually causes by output IC (or input IC) is defects.
It also can cause by AD/DA IC is error.
Mar 15, 2015 | Roland Music
How to repair my techno phone when it heats
Justice moris if you are Technician, go ahead otherwise show some official repairer to fix it, for the heating, problem is a charging ic water damage or broken, so change the charging ic near the battery connector and if problem persist change resistor near charging ic. this solution 90% helped in this kind of cases, if my answer was helpful please rate it, also you can search on gogle.com for the charging ic ways. Bes of Luck.
Jul 12, 2012 | Cell Phones
THIS TVFACEBOOK HOW DO U GET UR PIN GOT N LG LE5900
hello i want to know about TCL 21e20 power ic regulator description about the ic coz i the ic is broken i cant read the description please help me
Dec 14, 2010 | Televison & Video
I m using nokia e 63 n i had gone to nokia care and dey were sayng my ic is broken so tell me the use of ic n i m regularly facing software corrupt problem is this problem associated with software
The IC is an integrated circuit chip and this cannot be repaired, it is possible to replace the IC chip on the motherboard provided something else has not caused this IC to fail.
This is a hardware fault and is not associated with software.
Most likely the cost to repair the phone would be high and it would be more cost effective to purchase a new cell phone.
Dec 07, 2010 | Nokia E63 Cell Phone
NOKIA N70 Screen problem
it is white screen on display or black?
white screen problem can come from the ASIP filter on the mainboard.
change the ASIP or it usualy called Display IC.
before you change it, try with other LCD.
why the IC Display easy to broken.
cause it placed near the backup bateray.
the bateray producing liquid and the liquid make the IC Display broken
Sep 23, 2009 | Nokia N70 Cellular Phone
Red and blue overlap shadowing
Sounds like a convergence ic problem, normaly i tell people to replace the ic's but in your case try to re-solder the pins on the ic first, you may just have some pins broken loose from the board. Locate the stk392 ic's there will be two of them located on a heat sink, unplug the tv and get to the bottom side of the board and re-solder the pins. if this does not work, then replace the ic's
Sep 02, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Bad Solder
I don't know if you can buy the boards anymore, ive always replaced the IC checked the resisters, i can point you to two websites that have instructions.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
i would also replace the IC with the stronger ones stk392-180's and i would replace both no matter what.
Dec 10, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Tv tube problem
It`s total vertical collapse, which means 3 possibilities, vertical IC has failed, vertical IC solder connections are broken, the B+ line (voltage to make IC run) to the vertical IC has failed. None of these problems are big dollar repairs, 1/2 hour repair by any qualified tech, Good Luck & Happy Holidays, BMW Rider
Dec 03, 2007 | Televison & Video
Broken IC
Did the Sony service station say they can fix it? I would have Sony fix it for you at what ever the cost. It will be cheaper than buying a new player. If it cost more than 50% buy a new player and throw the broken one away. What IC"? Are you talking about an Integrated Circuit? Unless you have the "exact" part number, we can not help you. Even if you have the correct part number, they might not be easy to get or find. Then how are you going to repair it? Do you have the correct soldering iron and equipment? This is not what you want to heard but I would do the first thing I suggested.
Sep 24, 2007 | Sony NW-E507 MP3 Player
Altec Lansing ATP 3W Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
