Transmission will not engage in drive or second,if you put in 1st gear position truck will drive as it is supposed to do and pull off as it should. Once it is going you can shift to Drive and it works fine until you have to stop and then you have to shift back to 1st gear position to get it going again. Truck will down shift from 3rd. to 2nd when needed,and it will go in overdrive when it is supposed to . no lights or indicators are showing. Thanks for the help.
Sounds like you need to change transmission fluid and filter. Buy some synthetic AF fluid, cheap or expensive they will all do well, Also change out the transmission filter.
thank you, I have already change the transmission filter. I will try changing the fluid to see if that helps thanks again
I have this exact same issue on a 2001 NPR....did a simple filter and fluid change solve the problem?
Also have same issue on a GMC w 5500 did the filter and fluid change fix this problem
Did you ever get an answer to this? Ours does the same thing.
