Televison & Video Logo
Question about Philips Televison & Video
Need the service manual for a Philips Magnivox TS3258 C101
Components at G5 #2634 and H4 #7629 on the motherboard have burned out and I need to know what to replace these with.
Philips Magnivox
Model: TS3258 C101
Serial: 13312824
Chasis: 32D700-7570
Date Code: Manufactured October 1998
3318R232C
Posted by support125 on
Anonymous
    Brigadier General:
  • 3,614 Answers
I'm looking for a Philips/Magnavox TS2754 C101 TV Manual
ForVP87800
I have an Owner's Manual for your Philips Magnavox TS2754 C101
2helpful
Need instructions and tv code for magnivox tv from philips universal remote control
These are the codes, 0807,0002,0502,0919,1914,0224,0430,0247,0402,0408,0109,0715. hope this helps..
1helpful
Philips 27S300 C101 TV. How do I program the channels into the Philips TV. It's hooked up directly to cable. Right now I need to type in the channel I want to view. The channel up and down button skips...
use this user manual because you will continue to get some problems with your TV. print this use manual;
http://www.p4c.philips.com/files/2/27pt643r/27pt643r_dfu_aen.pdf
2answers
My philips magnivox rear projection TV has a cloudy picture..is it worth fixing
Yes, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
E2 Front
I needed help with an error message E2 (Front) on my Magnivox DVD Recorder MSR90D06 not a 30" TV. I will try to locate the manual and replace the wires on the back of the DVD to see if I can get it to work. Thanks anyway.
OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
