SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
had same problem. I figured it out. While pressing the home key on the bottom of the tablet, press the on/off button until a black screen appears with green words on the side, which says upgrading...please wait...wait. It should take you to the Pandigital screen with a small bar underneath it with green going across. It should work.
SOURCE: I have locked my MID Android Tablet. I have
pls try reset your mid tablet pc, if it can't, maybe you can contact your seller. if you can't contact your seller, you can ask another mid tablet pc seller online help sevier. as: http://www.mcwto.com, they are an mid tablet pc wholesaler.
SOURCE: have a white screen on tablet can' turn off nor on pandigital
Very gently unplug the battery cable for two minutes.. I used a pair of tweezers and worked it out. Plugged it back in and it is fine. What a relief. I have read that if it goes to sleep while plugged in via usb, it freezes? Don't know. Just be careful when pulling the battery!
