it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Did the circuit board get wet? Its behind the fascia panel. You will need to remove the top cover to see. Screws are at the back of the top cover. Remove them and slide the top backwards to get the top off. Look for any water marks. Best luck
