Question about Eaton Computers & Internet
I have a EATON EX RT 11 that shows ;DC BUS FAILURE - 1CM15046 V02' error on screen. What causes this error? How can this be repaired? Unit is out of warranty
The UPS when started automatically go to bypass mode, when i push 'ON' it will shut down.
Posted by Mustafa Ali on
  • Mustafa Ali
    Mustafa Ali Feb 22, 2015
    when i switch from bypass to normal, the normal power breaker use to trip. in the attached pic, the big fuse (100 A) found tripp.
victor vilca figueroa
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I HAVE THE CODE 1CKI46013 / V00D ... HELP ME PLEASE!!
Posted on Mar 06, 2018
Gruber Power Services
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 176 Answers
Replace your batteries
Posted on Mar 02, 2015
2 Related Answers
SOURCE: Powerware 9120 DC Bus Fault Problem.
there is a 100uf/63v capacitor near the IRF630 fet. You need to replace this in order to fix this error. Along there is also a 2200uf/16v capacitor. It is a good idea to change the both at the same time.
Posted on Feb 05, 2008
windso
SOURCE: Eaton EX RT 11, Windows
Matias,
Try using the Intelligent Power Software Suite (IPSS):
http://powerquality.eaton.com/Products-services/Power-Management/Software.asp
If you are trying to monitor the UPS, use Intelligent Power Manager (IPM). If you are trying to shutdown the Virtual Machine safely, use Intelligent Power Protector (IPP).
Posted on Jul 01, 2011
HI everyone I've got several UPS Eaton EX 3000 installed in solar farms and ALL of them are malfunction
call the ups engineers for an answer to the problem when connected to solar power
there may be a problem in that solar panels produce various voltages during the day ( depending on the cloud coverage ) and the ups requires a reasonably steady input voltage to operate properly
I have found the eaton ups product to reliable so the suggestion to talk with the engineers to ensure that the system is compatible with the solar set up would be to your advantage
Jun 21, 2016 | Eaton Electrical Eaton Ex 3000 Rt 3u Xl...
The output voltage is 101 volt between la y n, I expeccted 120 volt
There`s two configurations that you need to check.
On UPS display, what voltaje is showing as output voltage?
There`s a chance that it is configured to 200 vac, then the transformer module will convert this to 100/200 vac.
If this is not the situation, probably the error is in the input connection of transformer module.
Sep 09, 2015 | Eaton MGE O.P.S. EX RT - UPS - 8 kW -...
DC Bus Fault Error
Dc bus error is from charger o maybe inverter
Mar 24, 2015 | Eaton Powerware® 9120 UPS System
How to change the fans?
Take all steps to bypass the UPS according to the manual.
Turn the UPS.
Loosen the front plate.
The fans sitting screwed onto another plate which can be unscrewed.
Jun 11, 2014 | Eaton Electrical Eaton Ex 3000 Rt 2u 120v...
Cannot play the cd and displays error e-11
Error Code E11 is "SPI bus failure" the correction is "check and repair wiring harness" if OK "replace audio unit" this from the Fords workshop manual.
Hope helps (remember to rating this free answer.
Oct 07, 2011 | Car Audio & Video
DC Bus Low
This could be because of bad batteries or you need to adjust the float voltage. First replace batteries
Aug 12, 2011 | Eaton MGE COMET EX RT 11KVA 6U OL UPS 3:1...
Eaton EX RT 11, Windows 2008 server, in a VMware senario. PSP can't connect tu the UPS. Thanks in advance, Matias.
Matias,
Jun 20, 2011 | Eaton COMET EX RT 11KVA 6U OL 3:1 IN / OUT...
Is the fuse in a powerware 9135 user replaceble
There are numerous fuses (rectifier, inverter, charger, battery) on the 9135 that are located internal to the unit and not readily accessible to the user. Generally a blown fuse is accompanied by another component failure which caused the fuse to blow in the first place. As a result, additional troubleshooting and testing is usually required to identify the root cause of the failure. This of course leads to soliciting the services of a technician who has access to the schematics, test equipment, and parts to initiate a repair. Without the schematics, it's like working in the dark. For complete support, please contact Eaton (Eaton bought Powerware so now it's the Eaton 9135):
Toll Free: 1 800 356 5737
E-mail: [email protected]
www.eaton.com/9135
Jan 05, 2011 | Eaton Powerware 9135 UPS (700465446) UPS...
Feb 13, 2007 | Powerware 9120 UPS System
Computers & Internet Logo
1,166 people viewed this question
Top Eaton Computers & Internet Experts
Gruber Power...
Gruber Power...
jimixclay
Tom Chichester
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
