SOURCE: Need to know how to transfer my photos from my camera to my computer
1. In the absence of the type of your digital camera, I will assume that you are using a USB connection to link your camera and computer.
1. Connect your camera to the computer with USB cord when the camera is off.
2. Switch on your camera
3. If the Camera window doesnot appear automatically go and click the Start button then select the Control Panel
4. In the Control Panel Select the Scanners and Camera icon then you will see your camera displayed on the opened window of Scanners and Cameras
5. Double click the camera icon on the screen and you will immediately see the pictures in your camera being read.
6. A box with the Scanners and Camera Wizard will eppear with "Back", "Next" and "Cancel" click Next and then the pictures in your camera will be displayed with ticks markings
7. If you want to copy all into "My Pictures/..." just select Next and the computer will start copying them.
8. If you do not want to copy all of them then you can unmark those you dont want to copy and click next.
9. Once the copying is through you can rest assured your pictures have been transferred to your computer.
I wish all the best with your new photos on your laptop! Please remember when you are through to switch off the camera to preserve the battery for the next pictures to be taken.
SOURCE: transferring photos to computer
see first urs usb cabel is well fitted in urs pc or not or wid camera.....
if it is fittd well n u r unable to transfer ur photo.....then restsrt urs pc n camera at sm time n see it connected or not....
if all off these methods r useless then transfer urs photoes by using card reader......
but usin carrd reader u can only transfer urs memory card pics...
n also check urs usb slot in pc by attachin urs mobile or ny other device...it works or not....
ask me if it creates more problem.....
thanks...
A good reason to use the 'copy' function whle transferring. Doing this will preserve the pix in the camera memory until you are sure they actually arrived on your computer.
If you have a card drive, you might pull your memory card and plug it in directly to see what might remain there.
It may come up as only a 'removable drive' that you can address as if it was any other.
SOURCE: Can´t transfer photos to computer
i need the software that will transfer the pictures from coolpix 3700 to computer
SOURCE: problem transferring photos to computer
Bypass the clumsy software and USB port altogether: see if you can upload to your computer using a CF card reader.
If it works you'll get quicker uploads as well, and if it doesn't work then you have a faulty CF card and will need to try reformatting it (in the camera, not using the pc!) or will have to replace it.
Another possible solution is to reinstall the KM software to your computer as the KM software is quite buggy and seems to corrupt quite easily.
