Question about Epson WorkForce WF-7620 Wireless Color All-in-One Inkjet Printer
Why will my Epson wf7620 not print black ink after replacing the cartridge?
Jerry LaRosa
    New Friend:
  • 17 Answers
Hi. I don't know if your printer is new or old or if this was the first time you replaced the cartridge or this has occurred after several changes. Most if not all printers will have this occur after replacing a cartridge if the ink had been depleted for some time and allowed to dry up in the jets. Sometimes all it takes is a day for this to happen. I have found that I must go through several cleaning cycles to clear the clogged jet(s). So, try doing a few cleaning cycles and see if that solves the problem. Another cause for a printer not printing after replacing a cartridge is surprisingly a FAULTY or remanufactured cartridge. There should be a program on your computer that displays the cartridge condition, cleaning procedure and ink levels. Give that a look over.
Posted on Feb 20, 2015
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
I have just replaced the black ink on my epson sx210 and it is not recognising it.The other cartridges are empty. Could this be the problem?
Taken fro the epson site where they describe how to print in black only
notes.gif Note:
You will not be able to obtain black ink only printing if any cartridges have run out. This is to ensure that air is not sucked into the print head (instead of the ink that prior to the cartridge running out was available) therefore potentially damaging the printer.
In order to function, the printer will require black and colour ink cartridges to be inserted with a certain amount of ink in each cartridge.
Jul 21, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Ink
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 19, 2008 | Epson R245 InkJet Photo Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Printer will not print black, but will not let me replace black cartridge
The Epson FAQ lists several techniques for resolving this problem. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14374&infoType=Overview There is also an animation on how to replace the ink cartridges. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=HowTo&oid=14374&prodoid=11473
Oct 14, 2006 | Epson Stylus 880 InkJet Color Printer
Epson WorkForce WF-7620 Wireless Color All-in-One Inkjet Printer Logo
3,711 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
