Question about Lacrosse La Crosse Technology Atomic Clock With Outdoor Temperature And Weather Forecast
How do I chage time on a lacross clock
How do I chane time
Posted by Fern Reemts on
eskyfan
    Habit-Forming:
    New Friend:
  • 10 Answers
Hi I am giving you a link to the La Crosse website where you just enter your clock model number and you get the manual for it. There also are videos if you need more assistance.http://lacrossetechnology.com/support/manuals.php
Posted on Mar 02, 2015
Need instructions to manually reset time on Lacross atomic clock model 513-149
Hello, Donna -
I hope I am correct in thinking you do not have the user's manual for the clock. If so, you can find a PDF document of the manual (free) here:
http://office.manualsonline.com/manuals/mfg/la_crosse_technology/513149.html
You will need Adobe Reader software to open the PDF document, download it, save it to a file in your Documents folder (I suggest you name the saved file something like LaCross Atomic Clock Manual), and print it for easy reference.
Jan 11, 2018 | Home
Setting time on LaCross Projection Clock for bedside table
Google (LaCrosse)(model)(manual) without parens for information.
Nov 07, 2016 | Audio Players & Recorders
How do I chage time on lacross clock
An atomic clock, by definition, sets the time automatically.
Feb 19, 2015 | Lacrosse La Crosse Technology Atomic Clock...
Need to set time for daylight savings time
You can go to the LaCrosse web site for the answers for your clock
Mar 16, 2014 | La Crosse Technology Wt-3128u 12-inch...
The second hand on our LaCrosse atomic clock has stopped moving but the clock continues to keep perfect time. How do we get the second hand turning again?
The manual for one of their clocks says the clock will change the second hand to two-second intervals to conserve energy when the battery voltage gets low. Perhaps your battery is VERY low.
Mar 25, 2011 | La Crosse Radio Controlled Atomic Clock
How to set time?
This link goes to downloadable instructions for many LaCrosse clocks. One should work for you.
Feb 04, 2011 | La Crosse Atomic Projection Alarm Clock In...
How do you manually reset a Lacrosse Atomic Clock. Ours is always 4 hours behind and has not caught up. We already changed the batteries.
There are many LaCrosse atomic clocks. Which model do you have? Support for most is available here: http://www.lacrossetechnology.com/support/home.php . Use the drop down menu to select the model.
For the analog clocks, there is a manual set button on the back of the clock. Press the button and wait for the clock to advance to the correct time. Then make sure the correct time zone button has been pushed. Then make sure the clock is in a location where it can hear the signal overnight. (For best results stand the clock upright in a window.)
For WT-2165U travel alarm, press and hold Set to enter the setting function. Then select the time zone (with + or -) then press and release Set. Set the DST setting to on or off as needed, then press and release Set again. The next setting option is the snooze alarm duration. Press and release Set again to change the hour manually (+ to increase). Press and release Set again to set the Minutes. Correct the date (year, month, day, day of week) similarly. Then set the display to 12 or 24 hour time. Press and release Set to finish and exit the set functions.
For some of the digital clocks you can set the time manually by pressing and holding Set. First set the time display mode (12/24), then press and release Set again. Then set the hours, followed by Set and then the minutes. Continue through other menu options or just do not press any buttons for several (30) seconds.
On the digital clocks, the item being changed will flash.
To avoid interference with the signal reception, place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal.
I hope this helps.
Feb 03, 2011 | La Crosse Radio Controlled Atomic Clock
I have a lacrosse technology wall clock how do i set the time
You don't set the time. You set the Time Zone and it sets itself.
What model is YOUR clock?
This site lists several models of La Crosse wall clocks with downloadable instructions.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
The link below is generic but there are specifc downloads for clocks with other features.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Jun 18, 2010 | La Crosse Radio Controlled Atomic Clock
Lacrosse La Crosse Technology Atomic Clock With Outdoor Temperature And Weather Forecast Logo
515 people viewed this question
Top Lacrosse Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lacrosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
