Question about Reddy Heater-30-55,000 BTU Variable
When the heater is turned up to a higher btu , it cuts off after a short time
Model no. RLP50VA , REM50PVA OR BLP50VA
dwhandys
    New Friend:
  • 35 Answers
What size tank? when it's really cold a small tank will not produce enough vapor fast enough. It could be a weak valve in the tank snap'n shut If the fuel comes out to fast. Could also be high temp switch on back of burner going bad. That happens alot.
Posted on Feb 24, 2015
1 Related Answer
Anonymous
SOURCE: Won't start
if the propane cylinder is almost empty you maybe getting a concentration of murcapton(spelling?)this odorant is added to propane so it has an odor.when the gas gets low in the cylinder you can pull more odorant that may have settled in the bottom of the tank over time. there are other reasons since you are dealing with an unvented heating product , such as other odors fron oils,cleaning products, paint, etc. there could other problems so you may want to take it to your local propane store. jr
Posted on Mar 29, 2009
Reddy heater 60 starts runs a short time and cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 26, 2011 | Reddy Heater 60,000 BTU Kerosene...
Ihave a 175000 btu Lite 2 Jandy Pool Heater model # LD175P. It takes approx 3 hrs to go from 48 degrees to 100 . Why so long?The spa is 7ft in diameter and normal spa depth.Should I have a more btu heater?...
That seems to be a pretty good heating rate. You're talking about 52 degrees in 3 hours. If you want quicker heating, you will need a higher output heater.
Gary
Jan 06, 2011 | Jandy Pool & Spa
What is the meaning of BTU?
British thermal unit: a unit of heat equal to the amount of heat required to raise one pound of water one degree Fahrenheit at one atmosphere pressure; equivalent to 251.997 calories. The amount of heat needed to raise 1 pound of water 1 degree F (equal to 252 calories).
(British thermal unit) Describes the heat value of fuel for appliances - the higher the BTU, the more heat available for cooking.
A Btu is equivalent to 252 calories and serves as the base unit for measuring the heat content of a fuel source.
-The Ugly Pool Guy www.wefixuglypools.com
Dec 09, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
I have a Rinnai 556F Heater and I set it to a specific Temperature and a temperature higher is always flashing. What is wrong?
The temp you are looking at may be an error code. 72 Room sensor, 68 Over heat, 76.80 Room sensor short, etc. What is the exact code??
Tom
Oct 14, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Error code 31, heater not working, red light flashing
There is something wrong with the room sensor. Wires cut, shorted or disconnected.
Tom
Oct 03, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rennai Cosyglow RE650 that cuts out after a very short time and will only stay on if you hold the ignition lever down.
Sounds like the thermocouple needs changing. This is the flame failure device, they can burn out after a few years. Recommend getting a technican to fix it but you could ask him to make sure he has a thermocouple for this model on his first visit to save paying for two calls.
Aug 23, 2010 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Temperature fluctuates while flow remains constant.(within the pump cut in/out settings) Max temp obtainable 43c
This sounds like a common problem with tankless type water heaters. The modulating burner has a set Btu range it can operate within, a maximum and minimum. With very low flow rates and very low temperature rises, the burner has trouble maintaining a steady output temperature because the btu load drops below the heater's minimum input. Typically the machine will overheat the water beyond it's setpoint, the burner will cut out, and then re-ignite once the output temperature has dropped low enough.
The solution to stopping this behavior is to simply increase the water flow through the device (i.e. higher flowing fixture or larger pump). This type of problem is exaserbated with recirculation systems that bring a very high water temperature to the unit.
Higher end tankless brands have a lower minimum input btu and thus fewer problems with this.
Aug 17, 2009 | Bosch Water Heaters
Won't start
Jan 19, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
110 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
