Coby DVD-224 DVD Player Logo
C
Christine Posted on Feb 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote will not work. Only on/off, open/close and play at first option only Please tell me how to fix it to do command buttons
Chuck
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on Feb 19, 2015
 Chuck
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
79055
Points
573
Sometimes some of the touchpad buttons (just a plastic membrane inside the remote) corroded and won't work. Have you replaced the batteries?
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
1helpful
4answers
I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
tip
Matsui DVD-110 VCD Fix
Matsui DVD-110 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-110 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-110 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Matsui DVD-110 DVD Player can now play VCD's.
I hope that helps.
___________________________________________
Matsui DVD-110 Region Free Fix
on Apr 25, 2010 • Televison & Video
tip
Matsui DVD-122 VCD Fix
Matsui DVD-122 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-122 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-122 DVD Player:
Your Matsui DVD-122 DVD Player can now play VCD's.
I hope that helps.
Matsui DVD-122 Region Free Fix
3helpful
2answers
Have a 96 VS holden calais the drivers door central locking mechanism will not work. Pushing the remote all three doors (2 rear and passenger lock and unlock ) except the drivers door. When sitting in the...
aaahhh...im glad i have someone that gives enough information to solve your proble,......the short answer is the drivers door lock motor.......the info that you provided proves that the remote is communicating with the vehicle, and that the wiring is good and sound......the part that you ned to know and understand is that door lock motors come in 2 main types. Master and Slave.
The back doors are slaves and they do what the master tells them, self-explanatory.
The front doors are masters. On the calais, there is an option for 2 stage unlocking, where one press of the remote opens the drivers door only, and the second press, unlocks the rest commanded by the passenger door, which is a master.
The master door locks have a remote section and a hardwire section. The hardwire section works because unlock/lock of the drivers door commands all the others but the remote section (electric motor - push/pull) is not working, hence it wont work by itself.
get yourself a 2nd hand drivers door lock motor and this will fix all your problems
hope this helps
2answers
Face is stuck in odd position, won't close/open play
does your stereo have a reset button ?or does it have FACTORY SETTINGS option in the settings menu ?
First try these options ,then write in FixYa with the model number .
tip
Tevion DVD-200 VCD Fix
Tevion DVD-200 DVD Player VCD Playback Fix
Would you like to unlock your Tevion DVD-200 DVD Player to play VCD's?
Follow these steps to unlock your Tevion DVD-200 DVD Player:
Your Tevion DVD-200 DVD Player can now play VCD's.
I hope that helps.
Tevion DVD-200 Region Free Fix
9helpful
5answers
Command codes
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
Printer installation problem
Please perform below steps :
1.open a Command Prompt window(click start---->run--->type cmd and press OK)
2.key sc config spooler depend= RPCSS (note the space after depend=) and press Enter.
Try reinstalling the printer.
Or
1. Start / Run / MSConfig / OK.
2. Select the Services tab.
3. Make sure that each of the following services is checked:
Plug and Play
Remote Procedure Call (RPC)
Remote Access Auto Connection Manager
Remote Access Connection Manager
4. Press Apply.
5. Press Close.
6. Press the Restart button.
Try reinstalling the printer software. If the issue does not resolve Please get back me.
Thanks
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
