Went to turn on my Tascam 302, all it does is buzz. If I press a button it looks like it says "err 1". Anyone know what the problem is?
Hello Ken, I was looking in the manuals of Tascam 302 and it does not refer to "ERR 1", it appears "ERR 2" and "ERR 3"
From what you describe, you may have a power supply problem in the low signal area, or have some of the mechanisms out of point, so you can see that the axes are turning
If you have technical features, try disconnecting the multipin cable that feeds the mechanics and check if the noise continues, if it does not appear, go reconnecting each mechanism separately and looking for which generates the problem, could be both, at that point I suggest, consult to a specialized technical service
I hope my comment has served you
Greetings Franco Dosil
Hola Ken, estuve buscando en los manuales de Tascam 302 y no hace referencia a "ERR 1", aparece "ERR 2" y "ERR 3"
Por lo que describes puede ser que tengas un problema de fuente de alimentaci?n de la zona de baja se?al, o tengas alguno de los mecanismos fuera de punto, por eso observas que est?n girando los ejes capstan
Si tienes conocimientos t?cnicos, prueba desconectando el cable multipin que alimenta las mec?nicas y verifica si continua el ruido, si no aparece , ve re conectando cada mecanismo por separado y buscando cual genera el problema, podr?an ser los dos, en ese punto te sugiero, consulta a un servicio t?cnico especializado
Espero te haya servido mi comentario
Saludos Franco Dosil
