Usually a leaking water valve can cause this. This can be caused by low or high water pressure or just a leaking valve. Remove the tube from the valve and if water continues to drip from the valve it is bad or the water pressure is wrong. If it does not drip, leave the water line disconnected from the valve and dispense some water from the dispenser to see if it leaks. If it does the water is bleeding over and the valve is bad. If the valve is not leaking at all insure the fill tube that goes through the box and supplies water to the ice maker is seated properly and sealed off with permagum for instance. Also make sure the freezer section is not too cold ie -15 or -20 as this could cause issues.
SOURCE: Water fill tube and fill cup for ice maker freezing up
If you would like to know how I did it, let me offer you my Premium Assistance Plan.
SOURCE: Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
SOURCE: water drips slowy into the ice maker causing it to
repair or, replace the the electromagnetic solenoid water valve that supplies the icemaker located on the back right corner of the refrigerator where the clear plastic supply tube enters the machine from the house water line
SOURCE: Kenmore Coldspot with 106 626636 ice maker. The
A frost build up, specially on the ceiling of the freezer, is a sign of
problem in the self defrosting system or damaged gaskets of the doors.
Therefore, check if the refrigerator is facing such a problem and
defrost the refrigerator. It would not cool well if the defrosting is
not happening properly.
Take care.
