Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Hi. I have a problem with Hotpoint wd420. It won t work. ON/OFF flashing light and dryer and time saver lights are on. And Wd 420 is taking water. What is the problem?
tom cassidy
    Genius:
  • Hotpoint Master
  • 1,585 Answers
Check door interlock
Posted on Feb 22, 2015
How do I turn off the time saver option?
You should just be able to press the button. Has the machine stopped working with the START light flashing and the time saver light on? If so, this is an error code indicating a motor fault. Please describe any other lights that are on and if they are flashing or solid
Sep 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
I have a hotpoint wd420. the door light is flashing the wash light is on constant and the machine wont work anyone any solutions please!!
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
Nov 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
WD420, drying high heat, time saver and ON/OFF buttons are flashing, no function out of machine at all
this usually means that the main pcb has a corrupted eprom or eprom memory has been wiped... you either need a new pcb with eprom or a new board pre-programmed.
hotpoints terms for error
Setup error: check eeprom
F09
Flash
OFF
OFF
Flash
OFF
Dec 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
I'm after some error codes please guys, It's flashing 2(Reduces Creases) & 4(Time Saver) I've been told that these 'do' mean something, but can I find out what it is....no Any help would be really...
List of the Error Codes I found on another site. I'm getting f04 light 2 (the "wash" light). Looks like you've got the opposite problem with your pressure switch stuck on full (f05).
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Sep 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Dryer not working on aquarius wd 420
call him explain still not working if hes not willing to help tell him your going to turn him into states attorney general you can file complaint online his company will get black mark and will haft to answer to the state!!!!! check for restrictions on exhaust hose-if not call reputable company and send bad mechanic bill!!!!
Jun 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
The on/off button and saver time buttoon are flashing
Yes I have the same problem but the Drying High Heat is also flashing
Feb 22, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd420 problems
we had this problem had to clean out the "self cleaning filter" this solved it for us
Dec 15, 2007 | Washing Machines
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
