Televison & Video Logo
M
Mr B Harvey Posted on Feb 19, 2015
Where will I get a replacement bulb for a hp 3690 heat lamp
Why adf lamp failure
ADF Automatic Document Feeder, Lamp failure:
This happened to me with a HP 3520.
I was under warranty, and HP replaced my printer.
Reason for Lamp failure: Either the lamp was not getting hot enough, or it blew out. You probably have to contact the printer company by going to customer service. If out of warranty search for a store that repairs printers. Some printers, the bulb is locked in. Other printers such as Brother the bulb is snapped in. So the question can you do it yourself? Note: Replacement bulbs may cost more than your printer. They are not cheap. The first option therefore is contact the company.
tip
Before buying a projector bulb
1. Always be aware of bulb usage hours: bulbs normally last ~ 2000 hours
2. If the bulb pops and goes out:
  • Follow the manufactures safety instructions for this condition.
  • Normally, the bulb will need replacing.
3. If the lamp just turns off:
a. If lamp hours were getting high and the picture was getting progressively dimmer, normally the bulb will need replacing.
b. If bulb hours were low or a few hundred hours from 2000:
  • Clean all filters and air ports.
  • Try the projector again checking overall projector ventilation.
  • There is a heat sensor in most projectors that will shut off the machine if it overheats, so air flow must be unobstructed.
c. If ventilation does not solve the problem:
  • Take out the lamp, following the manufactures instructions.
  • Inspect the lamp bulb visually through the lamp glass window.
  • Look for cracks or damage in the bulb and whether one or both of the lamp wire elements is detached from the top of the bulb.
  • In either case, the bulb is bad and should be replaced by purchase or possibly by warranty if the lamp hours are low.
  • Normally, bulb replacement is the solution, but other issues could also exist.
d. If the lamp looks undamaged and/or you are unsure of the status, the problem could be a lamp ballast, power supply, or main control board issue, and should be evalulated by a technician. Unfortunately, a bad bulb can also result from one of the above issues.
My tornado lava lamp doesn't work. A little plastic piece just bounces around on the bottom.
It's difficult to say based on your limited description. A lava lamp is a first of all, a lamp. Does the incandescent lamp light up? If not, replace it (it's the heat source which creates the swirling action in the attached "lava" globe). As for the plastic piece, perhaps it's part of the lamp-holder socket that broke off due to heat. Perhaps part of the switch.
In any case, the light light bulb probably burnt out. Believe it a standard 40 watt bulb, but be absolutely certain to check before replacing as you do not want to put a bulb with a higher wattage in there due to the confined space inside the lamp.
Instruction for a philips infraphil hp 3690 lamp
Philips Infraphil Hp 3690 ???????????????
Hp scanjet 3690 tarayıcının cd
dove posso scaricare il driver del hp scanjet 3690 ? grazie
7helpful
I replaced the lamp when and the red LED light
More likely a faulty ballast. Check connections.
2answers
MD5880N replaced bulb and worked for 2 hours now nothing
Place heat shielding around the lamp to prevent overheat; use cooling spray (freon) to cool any chips or, circuit boards near the lamp as you attempt to start the set check the lamp for the correct serial # voltage etc.
4answers
HP XB31 Projector heat senor
Hi Marc
How do you know that the sensor needs replacement ?
Could you please give me some of the sympoms first ?
This could be something other than a sensor.
2helpful
3answers
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
