Re: How do I reset it Acer aspire laptop if I can't read...
Language can be changed in control panel menu.quick tip is to google translate the word "language" from English to Japanese on another device...then you will recognise how Japanese write the word language.
Sorry look for the icon of the world this is international sign for language change button.Sorry look for the icon of the world this is international sign for language change button.
You can't post conmments that contain an email address.
If you are running windows, you can open up your control pannel (in classic mode...easier) then double click the icon named "Regional and Language options" (Which if your OS is in Japanese and can't understand the words, it's the icon with the picture of the world, and a clock.) Double click on that icon, then the first drop down menu has all the languages your OS supports.
If you want to remove this virus, you must uninstall the safesearch toolbar you have probably accepted with a web browser.
The process to remove this pollution is described here. Safesearch net SafeSearch Toolbar removal instructions
All laptops have a CMOS, or "Complementary Metal Oxide
Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system
time, date and BIOS settings even if the computer is turned off or the main
battery dies.
Individual Acer Aspire laptop models differ somewhat, but
the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer
Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online
computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other
external devices.
Turn the laptop over (bottom facing up), then touch
something metal to remove static charge. Removal
Remove the Phillips screws that secure the motherboard cover
(refer to your owner's manual if necessary), then release the cover from the
clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on
the right side of the motherboard. Unplug the cable, then remove the battery. Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold
it in place, then align the cover with the slots on the bottom of the laptop
housing.
Replace the screws, then turn the laptop back over. Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1,"
"F2," F10" or the "Delete" key) before the operating
system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's
manual to reset your time, date and desired system settings. BIOS Reset
Any time the CMOS battery is unplugged for more than a few
seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with
your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the
problem. http://support.acer.com/us/en/default.aspx
Hi:
Your Acer is a model that was able to be marketed in either the United States or Japan. If it was sold in Japan, the Operating system would be in Japanese as well.
