How many pounds of sloppy joes can I fit in my five quart crock pot?
Well, that all depends on how dense a sloppy joe mixture you make. If you add pounds and pounds of ground beef to the mix and just the sloppy joe sauce, then it would be many pounds.
But as for a good rule of thumb, "A pints a pound the world around" In other words, if you're making sloppy joes from the pre-mixed cans, just weigh one 16 oz (1 pint) can and that's 1/2 quart.
If you're making it yourself, we're back to the whole density of your chosen ingredents.
However, I've done a little research for you and based on the density of cooked beef and converting the weight of that cooked beef into the 5 quart volume of your crockpot, I've come up with the following info for you.
Cooked Beef has a density 129.52 Ounces per Gallon (a technical measurement)
So based on that data (not including your sloppy joe seasoning/sauce and other add-ins), you should get approximately 10.12 Pounds of Sloppy Joe Mixture to fit into your 5 Quart Crockpot.
I would guess that the amount would be just slightly less, since you might want a little room for putting on the lid, etc., but you should get around 10 Pounds to fit easily in your 5 quart crockpot.
I hope you find this Very Helpful and best regards!
