follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it
is usually located behind the upper grille and behind an access panel,
and above the lower panel. On counter top units you will need to remove
the outer cover to get to the bulb. If that doesn't solve the problem
check the on-off switch, and control board
Main Control Board
check the light bulbs, sockets and wiring. If they are good the main
control board might be defective.
Light Bulb Socket
and a new light bulb doesn't solve the problem, the light bulb socket
might be burned out and need to be replaced.
