Question about GE Energy Star WCVH6260F Front Load Washer
Some GE front load washers go directly into a pump out mode after any power failure (or if plug is pulled). This is to keep it from possibly over filling during a cycle restart.
Posted on Feb 28, 2015
SOURCE: making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Posted on Jul 05, 2010
