Question about Dirt Devil Easy Lite Quick Vacuum
Dirt devil easy lite. I vacuumed up a coin I think, the vacuum is now screaming.. How do I remove whatever it was that got vacuumed up?
Remove a quarter
Thatvacguy.com
  • Dirt Devil Master
  • 1,604 Answers
The coin may have broken the fan. You will need to inspect it to see if the coin may have gotten stuck somewhere causing the noise. Inspect the fan for damage.
Posted on Feb 19, 2015
How to open dirt devil kurv
Hi! To access the dirt cup and filter first remove the dirt cup from charger stand. Then twist the dirt cup to remove. Grab filter tab and lift up to remove from dirt cup. Twist filter to remove from adaptor. Any disassembly beyond this point is not recommended. Hope this helps!
Jun 24, 2014 | Dirt Devil KURV Hand Vacuum Champagne...
I have plugged in my dirt devil and it wont turn on. other things are plugged into the same plug in and they are working. is there a reset button on the vacuum?
Hello! The Easy Lite does not have a reset button. It does have a thermal protector that will automatically shut the vacuum down if it is overheated. This is usually caused by either a clog or a dirty filter or a combination of the two. Try these trouble shooting steps below.
1. Remove the hose completely from the vacuum from both ends.
2. Use a broom stick or something similar to gently loosen and remove any clogs from the hose.
3. Remove the dirt cup. Remove the red air director by turning 1/4 turn counter clockwise. Remove any hair or debris from the air director.
4. Remove the filter from vacuum base. Hold filter under running water to rinse. Allow 24 hours to air dry.
When the thermal protector is activated the vacuum must cool down before it will power back on. This can take up to an hour. Hope this helps! If you still have questions feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jun 03, 2014 | Dirt Devil Easy Lite Quick Vacuum
Dirt Devil easy lite vacuum makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi there! Sounds like that noise may have been your belt popping or breaking. Try checking the belt on the vacuum. If it has broken, replace with a Dirt Devil style 15 belt. Below is a link where you may go to purchase the belt if needed. Thanks!
Style 15 Belt 2 Pack
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
Dirt Devil easy lite makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi, it's Cindy from Crucial Vacuum.
From your description, it sounds like there may be something stuck in your roller or your filter may need cleaning or replacement. Refer to page 22 of your manual to remove your roller.
For optimal performance, your filter should be replaced every 3-6 months and washed every 1 month. Your filter is located under the dirt cup holder.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f43-easy-lite-cyclonic-hepa-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
I have a dirt devil easy lite... how do I empty the top canister? I know how to empty the bottom half.
The upper half is where the filter is.
Here is the manual:
http://dirtdevil.com/file/172/
Page 7 shows after emptying the lower container, "Twist and lift to remove dirt container lid."
Aug 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
How do you empty the dirt out of it
The plastic dirt holder should have a lever that opens the canister.Should come right out with a slight pull.empty contents into the trash.
Oct 21, 2010 | Dirt Devil Easy Lite Quick Vacuum
No clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Dirt Devil Easy Lite Quick Vacuum Logo
147 people viewed this question
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
