magicJack pc to phone, free local & long distance calling, magic jack voip phone Logo
Question about magicJack pc to phone, free local & long distance calling, magic jack voip phone
Why can't i make a call with my magicjack on the OS linux mint 17.1 Cinnamon ?
I get dial tone butno connection to person dialed
Posted by Marcy Gatanti on
1 Related Answer
Jezneca
  • 23 Answers
SOURCE: No dial tone
Sorry to ask...but do you still have internet connection?
Posted on Dec 03, 2014
1helpful
No dial tone
1helpful
How can I fix my majicjack plus to work with anew service provider?
tab_l.gif Answer tab_r.gif If you hear error 1 while trying to place a call with your magicJack, it means that you are not connected to the Internet.
You need to check your new internet connection first.
Then sign into
You must check your new internet connection gets to magicjack.com
sign into VoIP Phone Service Internet Home Phone Service Providers magicJack
Magic jack customer service
Phone: 561-594-9925
  • How to reach a live person:
    • They say this phone number is only for billing questions, but it is the only way to get a hold of a live person. The only other option is their online support which is basically useless.
  • Hours of Operation:
    • 11am - 8pm EST
  • Email:
    • This information has not been added.
      Click here to update this department.
  • Customer service link:
  • Description:
    • You can also try 561-594-2140.
I can't get a dial tone on my magic jack phone line.
If restarting doesn't work or the solutions on the web site, you likely need the unit replaced. Personally I like the plus better because it can plug right into the network, account can be transferred. Caution, it likes to run hot when used on network and will need a cool place.
Magicjack problem
Check you have internet connection. insert the magicjack and see if it installs itself. It should then be able to give dialtone.
Need Factory Restore for Stepnote Win XP OEM no disk
Microsoft is complete Bloatware
Linux last year had an awesome release:
Linux Mint Rebecca-Cinnamon it is a sweet running OS, there is even a Windows emulator to run Windoze software.
We have tried to hook up majic jack no dial tone please help
Need to get intrnet hook phone jack to modam!
4answers
Install Linux OS
I would recommend installing Linux Mint LXDE, Cinnamon or KDE, which is a free OS available for free download from http://linuxmint.com Cinnamon and KDE are full featured, XFCE is streamlined and slightly faster and a better choice for older computers with less memory and/or storage space. All versions come with Firefox and LibreOffice full Office Suite, capable of saving and reading files in the popular MS Office formats like .doc, .docX, .ppt and xls.
Linux comes with almost everything necessary to begin using the computer immediately after installing the OS.
To install it on a netbook or notebook computer, I'm assuming you don't have a DVD optical drive so you have to install it from a USB thumb drive. If you have a DVD optical drive, I would still recommend installing it from the USB thumb drive, ... it's more reliable and less prone to failures from trying to burn a DVD on old, dirty or out-of tolerance equipment.
First download the .iso file on another computer. If you're not sure if your computer is 32-bit or 64-bit, you can use the 32-bit for both, or try the 64-bit - if that doesn't work, use the 32-bit.
Use a free program to create a bootable USB using the .iso file. (You can't just copy the file to the USB drive) ... I'd recommend using Active ISO Burner from NTFS.com ... here's the download link ... http://www.ntfs.com/iso-burning.htm (You should be using at least an 8 GB size thumb drive).
Once you've created the bootable USB drive from the .iso file, you should be able to insert it and start the computer and see the Linux Mint startup screen. It will come up in LIVE mode, without installing itself, so you can try it out.
If you want to install it, make sure you are connected to the Internet and have your AC power adapter plugged in.
If the computer doesn't come up with the Linux screen, you probably just need to reset your BIOS boot order so it boots from the USB driver first. Plug in the USB drive and start the computer. Look of instructions for set up or boot order, usually pressing F2 while the computer is starting. Follow the directions to move the USB to the top of the boot devices, i.e. about the hard drive. Save changes and restart the computer. It should now boot from the USB. If you have trouble doing this or burning the bootable USB, you might have a geek friend or relative that can help or do it for you.
When the LIVE mode comes up, it displays the Linux desktop with an Install icon. If you double click the Install Icon you will begin the installation process and just follow the simple prompts and create a password when prompted.
Linux never requires anti-virus and does not become infected. You can visit the main http://linuxmint.com website and download the .PDF manual if you are interested.
Your computer is probably 64-bit, but if not, there is also a 32-bit version available for download.
The image shown below is from my Acer and is Linux Mint KDE, which is also available from the same website and similar to LXDE, but more full-featured. All Google programs I know of are available for Linux, since Google uses 100% Linux. Android is Linux also.
Once you install your Linux, you'll want to run the Update Manager to get the latest updates.
On my Acer netbook I have 3 Linux OS's installed. Linux Mint Cinnamon 64-bit, Linux Mint KDE Cinnamon 64-bit and Linux Mint XFCE 64-bit. I select the OS I want at startup when the computer starts.
Top magicJack Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
john h
Tom Chichester
Are you a magicJack Computer and Internet Expert? Answer questions, earn points and help others
