I have a GE Washing Machine and I have a small drip coming from the spout that the water comes out of and accumulates at the bottom. We did the wash yesterday and this morning I noticed a little water in the bottom. What can I do to stop it? If I go on vacation I know a a leak could be catastrophic. I know I can shut the water off when not in use but that seems like not fixing the issue. Thanks
It is actually dripping into the machine not on the floor or in the back of the machine. How would teflon tape fix that?It is actually dripping into the machine not on the floor or in the back of the machine. How would teflon tape fix that?
You can't post conmments that contain an email address.
you most likely have hose leak some where on one or more lines coming into the washer, need to check both water lines from the wall and the machine itself. it mite be a little drip once in a while, but it is building up or storing the water in the drain pan.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
IF YOU HAVE STACKABLE SYSTEM CHECK THE DRIP PAN UNDERNEATH THE WASHING MACHINE.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
check the overflow line to inspect for cracking, or is the machine balanced while it spins.
the water in setting in the bottom of the washing machine, going to have to be taken apart and dried out,
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
just remember your machine always has water in it so when you do get to the pump and pull of the hose to the pump alot of water is going to come out. some washer have no bottom so tilt it over and look the pump will be transparent so you should be able to see if anything is inside the pump. have a shop vac ready.(all the water)
Could be a clogged screen on the back of the inlet valve. If you have hard water and no water softener, especially likely. Turn off the water at the water, remove the cold water hose from the back of the machine and see if there is an accumulation of white crumbly material just inside the body of the valve. If so, carefully remove it, then use a screwdriver to remove the protective screeen inside the valve. It is a press fit and will come out with a little effort. Do not puncture it. Clean and reinstall, hook up the hose and turn on the water. Check for leaks and you should be back in business.
it might be coming form the tub itself passing through the rubber seal of your plastic rotator(the big wheel inside the tub)
the other thing is in the junction of the hose the tub.
try to open the back of your washing macjine where you can get an access inside the wheel and the junction connector, from there you will the cause of the leackage. try to put some water while looking at so you can see where the water is coming out
Water inlet valve: If water drips even when the
washer is off,check the water inlet valve. It is located inside the
washer at the back of the unit. The fill hoses are attached to it.
Replace if deemed necessary.
Water fill hoses: Check the water hoses from the
household plumbing. Tighten it or replace
it as necessary..
Main
tub seal: It is located between the
transmission and
the outer tub. To see the leak, fill the machine with water with small
amount of detergent then open up the machine's main access panel.. The
leak appears
at the underside of the outer tub, at or near the center. The seal is
difficult to replace and you probably should call a qualified appliance
repair technician.
Pump: You can spot the leak when the tub is
full of water if the pump leaks. The pump has two or more black rubber or plastic hoses
attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
Outer
tub: The outer tub can rust,
split, or be
punctured.You may have to replace the entire tub but its not economical
repair to do. Consult a qualified technician for details.
If the washer leaks only during the fill cycle, check these:
Air-gap
device: It is a small device found on most washers that
prevents the wash water from being siphoned into the household water
supply. It is located either mid-way along or at the end of the black
rubber hose that comes from the water-inlet valve. It is usually made of
translucent plastic. If one of the air-gap components deforms or
cracks, you have to replace it.
The
tube: It is a rubber tube that runs between the water-inlet valve and
either the air-gap or the inlet spout. If it cracks or breaks, it can
cause a leak.
Inlet
spout: It is a plastic spout found on most washers near the top of the main
clothes tub that directs the water into the tub. If the spout cracks or
breaks free of its mounting, it can cause a leak.
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge.
It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food.
This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
I'm assuming this is a G.E. brand because of the model number. Take the four screws off the very bottom panel of the front of the washer. Inside you will see a twist off rubber cap. Place a pan under it big enough to hold 2 quarts, and twist the cap open. When the water comes out and it is empty remove any accumulation of lint, loose change, etc. This should be done monthly to help the washer discharge the water on spin cycles.
Also, inside the door is a flat rubber ring. At the bottom pull the flap back. There are small holes there for the water to drain out. Lots of stuff accumulates there too, even as large as a pocket knife or ball point pen. Check that daily when washing.
I assume you have removed the lint filter at the bottom of the machine and cleaned it out to make sure the pump is not stalled on a 1 pence or bra clip. Can you hear the motor start to spin? If not its probably because the water level switch is gunged up at the bottom of its rubber tube where it comes from the drum. Remove the top of the machine and locate the pressure switch - usually a round black or white device about 80 to 100mm across with a rubber pipe on a small spout 8mm diameter. Take the pipe clip off using pliers to compress it and move it back down the pipe. Remove the pipe and blow hard down the pipe to try and clear the blockage - you will hear bubbles blowing in the bottom of the drum water. Also you could very very gently blow into the switch stub pipe and listen for it changing over - clicks usually twice each way - blow - two clicks, release - two clicks. Restore swtch pipe and try the machine again. Good luck.
