Question about Video Cameras
Hitachi dvd/cam will not let me finalize disk, says disk error on approximately 4 minutes to finish finalization? help!!  evelyn
Posted by adamneve on
  • Anonymous Oct 06, 2008
    It would let me record anymore even though there is 24+ minutes left on the disk. And it just says "CAnnot read disk" please help!
Richard Bigley
  • 67 Answers
Is it plugged into the mains when you are finalising? because it has to be for finalizing.
Posted on Nov 15, 2007
I have a H2160MW9A and am recording 1/2 hour segments. When I dub from HDD to DVD I am unable to finalize. I get an error E19 and says disk full. I can still record more 1/2 hour segments to the DVD.
You finalize the disk AFTER you have finished all the recordings on it. Finalizing makes the disk more acceptable (readable) to other players and closes out the disk.
Dec 24, 2016 | Hardware & Accessories
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
I sometimes get a blue screen problem, when my screen causes the system to stop. I wonder if I can update my software for my 4 years old LG laptop.
try to run disk scan for errors.
1) go to my computer.
2) right click on local disk c: drive
3) click on properties.
4) click on tools and on error- checking section click check now. on the little window mark both boxes there. and click start.
5) and finally click yes
reboot you pc and dont touch anything until the scan is finish... it automatically will fix erros if are found.
hope this help
Dec 01, 2010 | LG Computers & Internet
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Disk wont finalize samsung sc-dx103
Samsung support just told me that there has to be some space left on the disc to finalize it. In other words if you fill the disc with too much video, the disc won't be able to write the necassary info on the disc to finalize it. Support told me you needed 10MB to finalize. He also told me to leave 7- 10 minutes of free space which is ridiculous because the disc only records 20 minutes. I have complained to Samsung about this ommission from the manual and that the camcorder should know to leave enough space to finalize the disc.>
Aug 09, 2009 | Samsung SC-DX103 DVD Camcorder
DVD will not finalize
I had this problem and moved to "Ashampoo Burning Studio" it was free on a computer magazine had no more problems
Aug 08, 2008 | Samsung DVD-VR357
Finalizing
IF THAT DISC WAS RECORDED ON AND THEN REMOVED BEFORE FINALIZING IT WILL NOT FINALIZE. THE CAMERA LOOSES THE MAIN INFORMATION TABLE FOR THAT RECORDING. ONLY THING TO DO NOW IS, IF THE DISC CAN STILL PLAYBACK ON THE CAMERA THEN CONNECT IT TO A DVD RECORDER VIA THE AV PORT AND RECORD.
Mar 30, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Finalizing
All units are different but you'll insert the disc to be finalized,
go into your disc menu, edit disc and you should see a finalize disc.
The disc will finalize (this usually takes a few minutes).
You will no longer be able to record on this disc so make sure you are finished with it!
If the disc is not finalized, you will not be able to play it in any DVD player other than the one you recorded it in!
I know it's not step by step but I hope this helps :)
Jan 08, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dis did not finalize
bad dvd what brand uuseing to burn with philps is touchy are u addingto much to a dvd also i would do mor ethen 4 gb on a dvd 5 disk ok single layer burn it slow does it have a speed adjustment do 4x 8x max
Jan 07, 2008 | Philips CDR570 CD Recorder
How long does it take to finalize? Can I finalize on other recorders?
The finalizing time depends on the remaining time on the DVD-R disc; Approximately 8 minutes to finalize with 20 minutes recording time on disc Approximately 3 minutes to finalize with 10 minutes recording time on disc Approximately 2 minutes to finalize with no recording time on disc. DVD-R discs recorded on the DVD-Camcorder cannot be finalized on other DVD-R Recorders or PCs.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Video Cameras Logo
251 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
