Question about Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Proscan 37 inch LCD 37LB30Q Model
I cannot locate a outgoing audio jack on this TV. In order to get my surround sound to work I must be playing the DVD player, as I am plugged into the outgoing audio jack on it. ANy suggestions or help, please. It has a HDMI x2 hookup, whayever that is and is 3d compatable.
Posted by ricklyn_2000 on
Anonymous
I used a swicher box form monster I plug in my viedo games and cable tv into it and then you run the composit cable which is high def into the tv but the sound into the swicher box the swicher box sound is run into the surround sound you just hit a button and you have the sound go to wall mart has the box for 20 dollars
Posted on Jul 08, 2009
I can not get my surround sound to work with my sony bravia HBD-E570 blue ray, while watching dish
I use HDMI cables for my blue ray DVD player, not sure if you do. If so, make sure surround sound is connected to your TV in the right jack. My surround system is old, so only uses RCA's (red, white, yellow). I plug mine into the audio out jacks (red, white) just below the HDMI 1 jack. Only the red and white are required for sound but also can use video (yellow) for higher quality. That is the main audio out. Plug into that and you should have all sound that is on your TV also sent to your surround system.
If you need further help, reach me via phone at https://www.6ya.com/expert/lucas_1df14fee4a945e4f
Aug 02, 2013 | Sony Bravia Kdl 46Ex700 46 in. TV
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
I have a LG47" tv
Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Audio Players & Recorders
I've bought a panasonic sound surround dvd player and want to link it to a sky+ box and tv so that sky will play in sound surround. Can you advise on the wiring configuration please?
look at the back of your tv does it have a audio out RCA jack?
it should do plug in the surround sound into that using RCA cables
if your tv does not have audio out RCA jack then you can
get a adapter which makes scart connectors turn into RCA jacks get that off ebay
plug the yellow line to the tv and connect the red and white to suround sound
but with this there are a few problems sound will only come out when surround sound is turned on and skys sound will never play out the tv
if you switch to a PS3 or something it will not play suround sound
yuo best option is the RCA plugs in the back of the tv
because you have not written the model number of the tv or the suround sound i cant help any further
Jan 12, 2010 | Panasonic Home Theater System System
CAN I PLAY THE DVD PLAYER WITH SOUND THROUGH MY TV WITHOUT HAVING THE SPEAKERS CONNECTED?
You can set up your tv in this way. Hook up your dvd player directly to your tv and then hook up your surround sound reciever from the audio out jacks from the back of your tv. This should allow you to use either your tv volume or the surround sound feature. Hope this helps
Oct 21, 2009 | Samsung HT-Q40 System
Ibought samsung surround sound and hooked it to the tv,but it only works when i play dvd.how can i connect to my tv so i can surround sound from tv or drem box
connect audio cables from the audio out jacks on your tv to the audio in jacks on your samsung surround. they may be labeled video 1,2 or aux. if your using a cable box the cable box may have optical or digital input jacks. your samsung surround should have a digital in jack which requires an optical cable.
Oct 21, 2009 | Samsung HT-Z310T Theater System
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at [email protected] and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
Connect to dvd player
On the back panel of your tv you will see two audio inputs labeled AUDIO TO HI-FI. Plug your surround sound audio jacks, ( red and white ) into that. Plug your video jack ( yellow ) into what ever number input you are going to use for dvd, if needed. This will allow you to watch tv and hear it in your surround sound. You should also go to menu- then- audio option and turn off your tv internal speakers, this will allow your tv remote to control your volume of surround sound. Hope this helped.
Sep 07, 2008 | Hitachi 51F59 51" HDTV Projection...
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo Logo
616 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
