What happens when an adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
