Question about JNC Computers Audio Players & Recorders
Need driver to allow JNC digital voice recorder USB-100MP3 to speak to my computer running on window vista
Posted by chuaa on
2 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: JNC Voice Recorder USB-350
It does not, and you cannot - I checked. I'm not being mean, but Vista is incompatible with MANY, MANY products, which is why XP has been the standard for over 5 years now. This voice recorder was made before even XP became the standard. You will need an older computer to get it to work.
Posted on May 26, 2008
Anonymous
SOURCE: JNC usb 350 digital voice recorder
i have jnc usb-350;
i can not installing drive and software.
i can not capture data from voice recorder to computer.
Posted on Nov 13, 2008
Voice recognition using Sony ICD-P320 and Naturally Speaking
I would run compatibility check. It sounds like not compatible with Vista.
May 16, 2010 | Sony ICDP620 Digital Voice Recorder
I have a JNC digital concept power voice II
The part which shows the files to be downloaded from the JVC recorder does not open when the software starts up. It only opens when the recorder is detected attached to the USB port. I suggest 1. Start the software. 2. connect the JVC recorder to the PC with the USB cable. 3. Turn the JVC recoder ON. The recoder display says "PC link" and the files to download show up in Power Voice II on the PC. Michael C
Sep 30, 2009 | Audio Players & Recorders
I have olympus digital voice recoder vn . 480 oc and windows vista, not working, not transfer and not identifiquet the olympus digital... in the list of CD windows vista is out I need of sofware for...
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Mar 23, 2009 | Olympus VN-480 PC Digital Voice Recorder
Drivers for Olympus VN-4100PC Digital Voice Recorder.
12. Click Next
Mar 23, 2009 | Olympus VN-120 Digital Voice Recorder
File transfer VN-480PC doesn't work on notebook (Vista)
12. Click Next
Feb 19, 2009 | Olympus VN-480 PC Digital Voice Recorder
11. In the next window make sure the CD drive the digital wave player disk is located and is listed in the window
12. Check the "include subfolders" box.
13. Click Next
14. Choose "install anyway" and the device will install.
Dec 08, 2008 | Olympus VN-2100PC Digital Voice Recorder
i have jnc usb-350;
Jul 27, 2008 | Audio Players & Recorders
May 26, 2008 | Audio Players & Recorders
Driver for windows vista home premium
I have Windows Vista Home Premium. I do not have my original Olympus disc. I downloaded the driver from driver guide (http://members.driverguide.com/driver/detail.php?driverid=583812) > installed driver (in this case pencam.exe. After installing the Olympus software I hooked the USB cable up, turned on my w-10 recorder and let Windows begin it's search.
I manually pointed it to the pencam folder where it proceeded to load the drivers successfully. I am now able to transfer my files successfully. Hope this helps in some way.
Oct 17, 2007 | Olympus W-10 Digital Voice Recorder
I cant download any files
Hi guys
I had the same problem with Windows vista and here is how I got my VN-4100PC to work.
1. Download and install digital wave player file from: http://www.olympusamerica.com/files/digitalwaveplayer.zip
2. Vista updates can be found on: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1291&os=w
This do the trick!
K
Oct 04, 2007 | Olympus VN-2100PC Digital Voice Recorder
314 people viewed this question
Top JNC Computers Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a JNC Computers Audio Player and Recorder Expert? Answer questions, earn points and help others
