If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit. Eric
if you take the back off of your dryer and look for a little white thermo fuse with 2 wires on it if you unhook the wires and plug them together than start the dryer if it starts shut it off and replace the fuse and clean your venting
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
